Embedded Server
Consolidate Considerations of Intel® Xeon and Atom server Hardware, Firmware, Software, and Tools
Failed to run ICAT
AmyZhu1201
How to deal with the following error messages when running ICAT?
I made some computers be installed ICAT with same version and run same deck,
but only one with Intel CPU could work, the others with AMD CPU always show errors.
Is ICAT only executable on computers assembled with Intel CPU?
or what reason might cause these errors?
Process 'C:/Program Files/Intel/ICAT/bin/imadc_1_4_5.exe' exit with status CrashExit and exit code 1
CB failed to Synthesis split 1
Channel builder Synthesis failed
CarlosAM_INTEL
Hello, @AmyZhu1201:
In case that you refer to the Integrated Channel Analysis Tool (ICAT), your consultations should be addressed to the channel listed in the last note of the following website accessible when you are logged into your Developer Premier account:
https://designintools.intel.com/product_p/stlgrn160.htm
@CarlosAM_INTEL.
