Embedded Server
Consolidate Considerations of Intel® Xeon and Atom server Hardware, Firmware, Software, and Tools
307 Discussions
Question about Xeon D-2100 series circuit design
ZShin
Hi all.
I have a question about Xeon CPU circuit design.
In order to design the mother board I'm referring the CRB circuits, EDS and PDG documentations. (doc #573770-yubacity-10l-collateral-final-rev1-1, 568202_D-2100_EDS_Rev2_3 ,568130_Bakerville_PDG_Rev2_8)
But, some of the guides show different scheme on CRB vs PDG or EDS.
For example, on the PDG p.360 describes "unused SATAGP/sSATAGP pins must be terminated to either Vcc3_3rail or GND using 8.2Kohm to 10Kohm resistor on the motherboard. Either pull-up or pull-down is acceptable" however, on the CRB p.32, unused SATAGP 5, 4, 3 pins are floating.
So, this makes me confusing.
Please let me know, which guideline should I follow? or which guideline has higher priority?
Thanks in advance
Joe
CarlosAM_INTEL
Hello, @ZShin:
You should use the latest version of the documentation to implement properly your design because it includes corrections and workarounds that are not included in previous versions.
@CarlosAM_INTEL.
Leonardo_C_Intel
Hello ZShin
Thank you for posting in the Intel Community.
we have a forum for your specific issues and I am moving your question to Embedded Developers so it can get answered more quickly.
Leonardo C.
CarlosAM_INTEL
Hello, @ZShin:
@CarlosAM_INTEL.
ZShin
Hi, @CarlosAM_INTEL
Thank you for the reply.
Then, PDG is more reliable in this situation. Since, PDG updated this year but CRB's last update date is 2017.
Thank you again.
Best.
Joe.
