Embedded Server
Consolidate Considerations of Intel® Xeon and Atom server Hardware, Firmware, Software, and Tools
310 Discussions
VROC support on Intel® Xeon® W 11865 MRE processor
husainak
I am planning to develop a motherboard with  Intel® Xeon® W 11865 MRE processor and RM590E chipset.
I want to know where VROC is supported on this processor. The application is a 16-channel NVME storage. solution
Diego_INTEL
Hello @husainak,
Yes, VROC is supported for the Intel® Xeon® W-11865MRE, this is an Intel® Xeon® W processor.
You can check this link:
https://www.intel.com/content/www/us/en/software/virtual-raid-on-cpu-vroc.html
Supported Processors
  • Intel® Xeon® Scalable processors (Generation 1, 2, 3, and 4)
  • Intel® Xeon® W processors
  • Intel® Xeon® D processors
  • Intel® Xeon® E (No Intel® VMD. Limited functionality supported)
@Diego_INTEL
pratheeksk
Hello @Diego_INTEL ,
 In the "Intel® Virtual RAID on CPU (Intel® VROC) Supported Configurations " it says the chipset is C400, whether RM590E with VROC using RAID5 can be achieved using the Premium key
Can you confirm whether the following solution works? need help with VROC Key pins on the processor
Pratheek
Diego_INTEL
Hello @pratheeksk,
I found internally a diagram that was accepted that looks the same as you have shared, with 1 PCIe x16 and another one of x4, this diagram looks to be good too.
@Diego_INTEL
Chandraman
Could you kindly furnish a document that confirms the compatibility of Xeon® W-11865MRE with VROC?
I would like to know how to access the RAID KEY through the Series 500 chipset and which GPIO can be utilized for reading the VROC key.
Suresh
Diego_INTEL
Hello @Chandraman,
Being an Intel® Xeon® W processor, it is supported according to this link.
I'm sharing this article, it may help with the questions you may have.
https://www.intel.com/content/www/us/en/support/articles/000024550/memory-and-storage/datacenter-storage-solutions.html
Also, you may check the document #787385 - Intel® Virtual RAID on CPU (Intel® VROC) 8.2 Production Version (PV) Self-Encrypting Drive (SED).
@Diego_INTEL
Chandraman
Dear @Diego_INTEL,
Thanks for the response.
I've reviewed the "Intel® Virtual RAID on CPU (Intel® VROC) and Intel® Volume Management Device (Intel® VMD) Supported Configurations" Revision 3.1 guide.
In Table 3, the "Intel® Platform Support Matrix" doesn't include the Xeon W-11865MRE, which is a VMD 2.0 supported device. Additionally, the Xeon W-11865MRE utilizes the series 500 chipset, which is not mentioned in the matrix.
Could you please provide information on the 500 (RM590E) chipset support for VROC? Specifically, I'm interested in the GPIO that supports reading from the VROC key.
I am seeking a document that explicitly mentions Intel® Virtual RAID on Processor (Intel® VROC) (VMD NVMe RAID) compatibility on TGL-H based Xeon-W 11865MRE and RM590E chipset.
Thank you for your assistance.
Suresh
Diego_INTEL
Hello @Chandraman,
You can check the document #643013 - 11th Generation Intel® Core™ Processor-H and Intel® 500 Series Chipset Family Platform Controller Hub for IoT Platforms, here you can find more details of the RM590E and Tiger Lake H.
@Diego_INTEL
Chandraman
Hi @Diego_INTEL,
I have carefully reviewed document #643013 and additional documents, namely #615985 PCH EDS and #575683 CPU EDS, in relation to our ongoing project.
Our specific requirement revolves around ascertaining whether the Xeon-W 11865MRE with the RM590E chipset, supports VROC (Virtual RAID on CPU) for virtual NVME RAID configuration on CPU PCIe lanes.
To proceed with our design, we are seeking documentation that explicitly states whether the Tiger Lake H-based Xeon-W 11865MRE supports VROC. If such a document exists, could you kindly provide the document number?
If the Xeon-W 11865MRE indeed supports VROC, we need information on the mechanism by which the RM590E chipset can read the VROC premium key. Specifically, we request details on the GPIO pin designated for reading the key.
I humbly request your assistance in providing the necessary documentation to facilitate the progression of our design. Your prompt response to this matter would be greatly appreciated.
Thank you for your support.
Suresh
