Embedded Server
Consolidate Considerations of Intel® Xeon and Atom server Hardware, Firmware, Software, and Tools
303 Discussions
XEON D-1559 GPIO driver for windows 10 64 bit
OTal0
Hello
I need GPIO driver (chip set) for XEON D-1559 for windows 10 64 bit.
I cant find any at the download center and it is part of the chip set.
CarlosAM_INTEL
Hello, @OTal0​:
In order to be on the same page, could you please let us know if the affected design has been developed by you or by a third-party manufacturer? In case that it is a third-party device , please give the model, part number , and where is stated its documentation.
Waiting for your answer.
@Mæcenas_INTEL​.
OTal0
Thank you for your reply.
we are a third party manufacturer but my Q was all about on CPU GPIO driver.
since the GPIO HW is build in the chip set we would like to use a standard driver that can work on D-1559 processor.
there were no changes on host regarding this device.
Ohad
CarlosAM_INTEL
Hello, @OTal0​:
Thanks for your clarification.
You should implement the requested driver using the information stated in section 3.14 - General Purpose I/O (D31: F0), on pages 116 to 120 of the Intel(R) Xeon(R) Processor D-1500 Product Family External Design Specification [EDS] Volume 5 of 5: Integrated Platform Controller Hub document # 544044. Also as a reference, the information stated in the Intel(R) Serial IO Bus Drivers Product Requirements Document [PRD] document # 571354 may help.
These documents can be found when you are logged into your Resource & Design Center (RDC) privileged account at the following websites:
http://www.intel.com/cd/edesign/library/asmo-na/eng/544044.htm
http://www.intel.com/cd/edesign/library/asmo-na/eng/571354.htm
The RDC Account Support form is the channel to process your account update request. It can be found at:
https://www.intel.com/content/www/us/en/forms/design/contact-support.html
@Mæcenas_INTEL​.
