Community
cancel
Showing results for
Search instead for
Did you mean:
Athuljith
Xeon D 1559 LPC
How to Interface SPI flash of 256MB minimum, using LPC interface to Xeon D 1559? Is there a glue logic of FPGA/CPLD required to interface flash and LPC. Is there any LPC interface guide available?
Tags (2)
CarlosAM_INTEL
Hello, @Athuljith:
The information that may answer your question is stated in section 13 of the Grangeville with Intel(R) Xeon(R) Processor D-1500 Product Family Platform Design Guide (PDG) document # 543448. It can be found when you are logged into your Resource & Design Center (RDC) privileged account on the following websites:
http://www.intel.com/cd/edesign/library/asmo-na/eng/543448.htm
The RDC Account Support form is the channel to process your account update request or report any inconveniences with the provided site. It can be found at:
https://www.intel.com/content/www/us/en/forms/support/my-intel-sign-on-support.html
@CarlosAM_INTEL
Athuljith
Hi@CarlosAM_INTEL ,
Thanks for your response. I checked Section 13 of PDG document. As per the document The Maximum size of flash Processor can support is 64MB on each CS. But I have to use an 256MB flash to store my code. So I don't think I can directly interface flash with the processor. Can I use the LPC interface and a glue logic to achieve this? If so can you please provide some reference design. Or is there any other scheme to do this?
CarlosAM_INTEL
Hello, @Athuljith:
The information that may help you is stated in section  7.1.29, on page 282 of the Intel® Xeon® Processor D-1500 Product Family External Design Specification [EDS] Volume 5 of 5: Integrated Platform Controller Hub document # 544044. It can be found when you are logged into your Resource & Design Center (RDC) privileged account on the following websites:
http://www.intel.com/cd/edesign/library/asmo-na/eng/544044.htm
@CarlosAM_INTEL.
