Embedded Server
Consolidate Considerations of Intel® Xeon and Atom server Hardware, Firmware, Software, and Tools
262 Discussions
Xeon D DDR4 INterface
Athuljith
I am planning to use 16Nos of x8 wide 16Gb DDR4 chips (Total 32GB) per channel of Xeon D 1559 Processor. How could I interface these chips without using any mux in-between. Is there any DDR4 interface guide for Xeon D 1500 series.
Please Note: Board works in Industrial temperature (-40C to 90C)
CarlosAM_INTEL
Hello, @Athuljith:
We suggest following the guidelines stated in section 6 of the Grangeville with Intel(R) Xeon(R) Processor D-1500 Product Family Platform Design Guide (PDG) document # 543448. It can be found when you are logged into your Resource & Design Center (RDC) privileged account on the following websites:
http://www.intel.com/cd/edesign/library/asmo-na/eng/543448.htm
The RDC Account Support form is the channel to process your account update request or report any inconveniences with the provided site. It can be found at:
https://www.intel.com/content/www/us/en/forms/support/my-intel-sign-on-support.html
@CarlosAM_INTEL.
Athuljith
Hi @CarlosAM_INTEL
Thanks for your reply. I went through the section you mentioned in reply.
I think i have to detail my query. I am planning to use 32GB DDR4 per channel. The maximum memory size available in industrial temperature grade is 16Gb. So I have to use 16 Numbers. Processor is 64 bit data wide. So that I should chose a x4 wide 16 Nos. of DDR4 chips. But x4 wide chips are not available in that specified temperature grade. Least available is x8 wide. So now I am with 16 nos. of 16Gb, x8 wide DDR4 chips. Please suggest me a scheme where I can effectively use this DDR4.
CarlosAM_INTEL
Hello, @Athuljith:
We suggest using the devices that fulfill the requirements stated in the documentation provided previously and the ones listed in the document stated in the following website:
https://www.intel.com/content/dam/www/public/us/en/documents/platform-memory/ddr4-2133-sodimm-ecc-validation-results.pdf
@CarlosAM_INTEL.
Athuljith
Hi @CarlosAM_INTEL ,
Thanks for the respose. I checked those parts listed in that document. But I don't think any of them meeting my requirements. First of all we are not using DIMM modules. We have to use DDR4 chips. Our requirement is 32GB. So can you suggest a part which I could use for this
CarlosAM_INTEL
Hello, @Athuljith:
The tested and validated type of memories are listed in Table 6-2, on page 133 of the PDG mentioned on our first communication and the list cited in our previous message.
In case you want to use a different type or configuration than the listed in the documentation, it should be tested and validated on your own.
@CarlosAM_INTEL.
