Please provide
1. Power supply design guidelines/documents for Xeon D 1559
2. Recommended (or validated)DDR4 DIMMs with Xeon D 1559. Buffered or unbuffered DIMM is fine. 16 GB Capacity per channel with ECC. Need speed 2400 and dual Rank DIMM
Hello, @Jinto:
You can find the power guidelines in the Voltage Regulator Module (VRM) and Enterprise Voltage Regulator-Down (EVRD) 12.5 Design Guidelines document # 495853 that has information that may help you. You can find it when you are logged into your Resource & Design Center (RDC) privileged account on the following website:
http://www.intel.com/cd/edesign/library/asmo-na/eng/495853.htm
The RDC Account Support form is the channel to process your account update request or report any inconveniences with the provided site. It can be found at:
https://www.intel.com/content/www/us/en/forms/support/my-intel-sign-on-support.html
On the other hand, you may find the memory requested information on the following website:
In this link , what is meant by requires MRC 3.8.0 or later?
Hello, @Jinto:
Thanks for your reply.
It means that you should use the latest MRC available.
Hi
The link provided by you is for Broadwell EP
I am looking for power design guideline of broadwell DE (Xeon D 1599 is the part). Kindly share the relevant data.
Hello, @Jinto:
The cited has been suggested based on the information stated on page 76 of the Broadwell-DE SoC-Based Grangeville Platform Design-In Presentation for IOTG Customers document # 554143. It can be found when you are logged into your Resource & Design Center (RDC) privileged account on the following website:
http://www.intel.com/cd/edesign/library/asmo-na/eng/554143.htm
