Ethernet Products
5821 Discussions
Драйвер intel gigabit ct expi9301ct
RWah0
Снимок.JPGГде взять драйвер для intel gigabit ct expi9301ct?
Штатный который идёт с OC Win10 работает, но я так понимаю, что должен быть и от intel. Скачал от интел, там ошибка. Что не так то?
RWah0
Where to get a driver for intel gigabit ct expi9301ct?
AlfredoS_Intel
Hi RWah0,
Thank you for posting in our Intel® Ethernet Communities forum.
Before we answer your question, we need to get some information from your system. Please download and run our Intel® System Support Utility on this page, https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-. Please attach the text log, which it will generate, on your reply.
Alfred S
Intel® Customer Support
A Contingent Worker at Intel
RWah0
RWah0
AlfredoS_Intel
Hi RWah0,
We appreciate the time that you took out of your busy schedule to provide the logs.
After checking the logs, the card that you have only has Windows 10 inbox drivers. Please refer to this page, https://www.intel.com/content/www/us/en/support/articles/000025890/network-and-io/ethernet-products.html, for more information.
May I ask why you want to update the driver?
Alfred S
RWah0
Спасибо за помощь.
Потому что вижу, что драйвер от Win10 создан 2018. А драйвер для остальных сетевых карт от intel в 2019. Спасибо за помощь, буду использовать драйвер из коробки.
AlfredoS_Intel
Hi RWah0,
Thank you for your reply.
As a reminder, we only respond to posts in English, and since your post in a different language, we used a translator tool to understand.
Please let us know if you have any further inquiries.
Alfred S
AlfredoS_Intel
Hi RWah0,
Please let us know if you have any further inquiries with your concern.
Alfred S
AlfredoS_Intel
Hi Rwah0,
We are just sending another follow up to check if you still have questions or clarifications.
Since we have not heard back from you, we will need to close this inquiry.
If you need further assistance, please post a new question.
Alfred S.
Intel Customer Support
RWah0
Закрывайте тему. Вопросов больше нет. Спасибо.
AlfredoS_Intel
Hi RWah0,
Based on the translation of your last message, you said that you do not have any other question; therefore, we will be closing this post.
Alfred S
