Community
cancel
Showing results for
Search instead for
Did you mean:
SCroi
10G switch
Hello everybody,
I need to implement a 10G ETH switch with 4-5 ports. All ports need to be 10G copper.
I would prefer to be unmanaged switch because we want to use it strictly for switching routs.
Can somebody recommend a suitable chip for this purpose?
I looked at XL710, but I don't think it will work for our purpose.
Thank you for your help!
Community Manager
Hi Scroicu,
Thank you for posting in Wired communities. If you are referring to the the xL710 Ethernet controller, this
is used for network card or ethernet controller to be integrated on boards as an onboard NIC, not intended to be used in a switch.
You might want to check on the ethernet switch silicon listed below, however the products below are not support here in this forum.
https://ark.intel.com/products/family/134/Switch-Silicon
Hope the above information help.
Sharon T
SCroi
Thank you!
