Ethernet Products
5610 Discussions
1G NIC with suport for longest Super Jumbo Frames
PQ
Hello
i use adapters with i350-T4 controller. It supports only 9.5 kB frames. I nees work with much more, at least 20 kB frames, ideal 64 kB frames. Does Intel have ani NIC supporting it? Please help.
Thanks a lot.
Petr
st4
New Contributor III
Hi Petr30,
Further checking, unfortunately we do not have 1Gb network adapter supports your jumbo frames size requirement.
Hope this clarifies.Thanks.
rgds,
wb
st4
New Contributor III
Hi Petr30,
Thank you for the post. Let me double check on this.
rgds,
wb
st4
New Contributor III
Hi Petr30,
rgds,
wb
PQ
Thank you for the answer.
