Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
82562V 10/100 Ethernet Controller
Jump to solution
I recently updated to current driver version 9.14.180.0
Ever since doing so my 32bit Windows Vista desktop is doing two things:
A. Awakens from Sleep mode spontaneously (found this can happen from network activity). This did not happen with previous version.
B. The network plug in light on the back of my desktop stays lit when system is put to Sleep. It did not with previous version.
Is this 'normal' with this version? Can anything be done to 'disconnect' from the network when put to Sleep?
Mike
Accepted Solutions
Mark_H_Intel
Hi Mike,
Check the advanced and power saver tabs for your network connection in Windows Device Manager. (The quickest way to reach device manager is to run devmgmt.msc from the Windows search programs and files box you get when you cllick on the "Windows" icon. I can't remember if this was an icon or something more in Vista. I am using Windows 7 now.)
Look for any "Wake on" options and disable them. That will likely take care of the wake ups you are experiencing.
I hope this helps.
Mark H
Mark_H_Intel
Hi Mike,
I hope this helps.
Mark H
Community Manager
Thank you Mark! There was a 'Wake on' option which I disabled.
Mike
