Ethernet Products
4526 Discussions
82566 MM gigabit link down
CComa
Hi folks,
I have this adapter on a notebook Fujitsu Lifebook E8410. The adapter is gigabit capable.
The OS is Windows7 x64 home edition.
Problem:
When I set the linkspeed to 100Mb full duplex the adapter is working but performance is bad.
When I set the linksped to GB 1000 full_duplex it makes 2 tries (stay on 5 seconds each) then advertise cable unplugged / link down.
partner is gigabit router Netgear R7000 or gigabit switch tp-link
Troubleshooting done :
updated driver to latest (2013) by means of intel driver update utility. - no improvement
changed cable : cat5E shielded - no improvement
changed partners: Netgear R7000 / gigabit switch tp-link - checked Gb ports with other devices. - no problem
checked the RJ45 socket and tried also from port replicator RJ45 socket - no improvement
checked a GB network adapter on USB3.0 - it was running GB 1000 full duplex perfect / cable good
booted Ubuntu LIVE from Disk and checkd the intel ethernet - it as running GB 1000 full duplex perfect.
Conclusion :the ethernet hardware seems good.
The driver for Win7 X64 seems to have problems.
Any hint for advanced configuration/troubleshooting under win7 x64 is welcome.
Thanks in advance,
Cozmin
AP16
Valued Contributor III
CComa
I solved it but with an older driver (2010). ...and about the newest driver, your link points to https://downloadcenter.intel.com/downloads/eula/25242/Network-Adapter-Driver-for-Windows-7-?httpDown=https://downloadmirror.intel.com/25242/eng/PROWinx64.exe PROWinx64.exe (intel driver update utility) which, after instalation, is finding the 2013 driver of my intel ethernet card, as being the latest available.
Thank you for your time.
