Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Community Manager
82579LM - Windows 8 issue with ProSet and vlans with static addresses
Jump to solution
I am testing Windows 8 Enterprise 64 on an Intel DQ67SW motherboard. It has an 82579LM network card which I've installed with the newer ProSet 17.4 for Windows 8 (64bit) (also tried 17.3 with same results). Here is my problem : If I add a tagged VLAN and I set it with a static IPv4 address, the network card accepts it but keeps the "autoconfiguration IPv4 Address" (169.254.171.226) also and marks it has . Hence the network card is useless and routes aren't being set properly.
ipconfig /all :
Ethernet adapter Ethernet 2:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Intel(R) 82579LM Gigabit Network Connection - VLAN : VLAN1000
Physical Address. . . . . . . . . : 00-22-4D-6B-59-C5
DHCP Enabled. . . . . . . . . . . : No
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::75e5:55c9:c10e:abe2%26(Preferred)
IPv4 Address. . . . . . . . . . . : 10.0.10.5(Duplicate)
Subnet Mask . . . . . . . . . . . : 255.255.0.0
Autoconfiguration IPv4 Address. . : 169.254.171.226(Preferred)
Default Gateway . . . . . . . . . :
DHCPv6 IAID . . . . . . . . . . . : 436216397
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-18-36-4E-E6-00-22-4D-6B-59-C5
DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter Teredo Tunneling Pseudo-Interface:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
Tunnel adapter isatap.{CAAE7C0F-9462-45E9-9266-2E79108C7F24}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter # 3
any help? I've used ProSet drivers since forever on all past windows OS and that same problem never occured... so I guess it's a case of immature drivers?
Accepted Solutions
Highlighted
Community Manager
Alright so this all was a HUGE code 18 on my part.
I am building my "new" PC at work alongside my working one... and like an idiot I set up the same static IP on both! When I reverted to installing Windows 7 it popped-up an IP address conflit message which Windows 8 never popped!
So I went back to Windows 8 making sure to have different IPs and all is well.
No bug in the drivers, simply bad handling on my part.
thanks for the help Mark H.!
Highlighted
Hi Alex,
I have seen instances in earlier versions of Windows where the Windows network connection interface took awhile to initialize, and if you configure a static IP before the interface completed initialization, the static IP address failed. I think this might be what happened to you.
Try this:
  1. Remove the VLAN.
  2. Wait 60 seconds
  3. Create a VLAN using the VLAN tab.
  4. Do something else for a few minutes. A few minutes is probably longer than needed, but I don't know how to tell when it is safe to assign the static IP address.
  5. Assign a static IP address to the VLAN interface.
I hope this helps.
Mark H
Highlighted
Community Manager
Highlighted
I have to try to remember this symptom. Maybe Windows 8 calls an IP conflict a "duplicate." I hadn't thought of that when you shared the ipconfig information. Maybe Windows 8 is trying to be helpful by assigning an automatic address instead of warning of an IP conflict. I will watch for that situation in the future.
I am glad your issue is resolved. Have a great day.
Mark H
Highlighted
Community Manager
that would indeed make sense! Still they could've kept the useful pop-up to let us know that we just did something wrong on the network.
have a good one!
