Ethernet Products
5581 Discussions
82579V Causes Bugcheck 9f on Shutdown on Windows 8.1 RTM
MGrac
The crash occurred on a computer with the following parts:
Motherboard:http://www.asus.com/Motherboards/P8Z77V/ P8Z77-V - Motherboards - ASUS
Ethernet NIX: Intel 82579V
CPU: Intel i7 3770K
Here is the crash dump
0: kd> !analyze -v
* Bugcheck Analysis *
DRIVER_POWER_STATE_FAILURE (9f)
A driver has failed to complete a power IRP within a specific time.
Arguments:
Arg1: 0000000000000003, A device object has been blocking an Irp for too long a time
Arg2: ffffe000008b5880, Physical Device Object of the stack
Arg3: fffff802617e4960, nt!TRIAGE_9F_POWER on Win7 and higher, otherwise the Functional Device Object of the stack
Arg4: ffffe00003cc2290, The blocked IRP
Debugging Details:
DRVPOWERSTATE_SUBCODE: 3
IMAGE_NAME: pci.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 5215f837
MODULE_NAME: pci
FAULTING_MODULE: fffff80000538000 pci
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: WIN8_DRIVER_FAULT
BUGCHECK_STR: 0x9F
PROCESS_NAME: System
CURRENT_IRQL: 2
ANALYSIS_VERSION: 6.3.9431.0 (debuggers(dbg).130615-1214) amd64fre
DPC_STACK_BASE: FFFFF802617EBFB0
STACK_TEXT:
fffff802`617e4928 fffff802`600798d2 : 00000000`0000009f 00000000`00000003 ffffe000`008b5880 fffff802`617e4960 : nt!KeBugCheckEx
fffff802`617e4930 fffff802`600797f2 : ffffe000`025ed550 fffff780`00000014 00000000`00000001 ffffe000`02145748 : nt!PopIrpWatchdogBugcheck+0xde
fffff802`617e4990 fffff802`5ff026e2 : fffff802`601c8a80 ffffe000`029f39f0 fffff802`60170180 ffffe000`029f3a90 : nt!PopIrpWatchdog+0x32
fffff802`617e49e0 fffff802`5ffd2bea : fffff802`60170180 fffff802`60170180 fffff802`601c8a80 ffffe000`037a2080 : nt!KiRetireDpcList+0x6b2
fffff802`617e4c60 00000000`00000000 : fffff802`617e5000 fffff802`617df000 00000000`00000000 00000000`00000000 : nt!KiIdleLoop+0x5a
STACK_COMMAND: kb
FOLLOWUP_NAME: MachineOwner
IMAGE_VERSION: 6.3.9600.16384
FAILURE_BUCKET_ID: 0x9F_3_POWER_DOWN_e1c64x64_IMAGE_pci.sys
ANALYSIS_SOURCE: KM
FAILURE_ID_HASH_STRING: km:0x9f_3_power_down_e1c64x64_image_pci.sys
FAILURE_ID_HASH: {faf9d2cb-3f0f-1321-aad2-e9420358cf95}
Followup: MachineOwner
0: kd> !irql
Debugger saved IRQL for processor 0x0 -- 2 (DISPATCH_LEVEL)
You can find the full dump here:
<a href="https://docs.google.com/a/mgraczyk.com/file/d/0B-2un9FOvIMCQzZTcFZJTjI4RlE" style="font-size: 10pt; line-height: 1.5em;" title="https://docs.goog...
