Ethernet Products
5821 Discussions
82579V & Intel Network Connections 16.8 Problem
I have the Intel 82579V Gigabit NIC which is integrated in the Asus Sabertooth P67 rev 3.0 and any time I try to install the drivers for it (specifically Intel Network Connections 16.8) it can't identify the NIC correctly. What happens is this: I install the driver and it identifies the NIC fine and internet works but when I restart my computer it misidentifies it as some 82579LM (not sure if the number is correct but LM is at the end for sure) and internet doesn't work. I've tried a few different things and can't fix it. Went back to Intel Network Connections 16.7 drivers and everything is fine with those. I'm posting this so you can guys work out the problem and fix it in the next version release of the drivers.
Thanks!
Mark_H_Intel
Thank you for posting the information.
See /message/147366# 147366 http://communities.intel.com/message/147366# 147366 for my reply in the other thread. I plan to lock this thread, so please follow this link for any additional discussion.
Mark H
