Ethernet Products
4538 Discussions
82579V network adapter not recognized by PROset software
EHumb
Details:
Windows 7 64 bit
Gigabyte GA-Z77x-up5 th motherboard (F4 bios)
Recently installed 7260 ac HMWG wireless card. 17.1 driver Working fine. 15 MBS
Problem: The network interface (wired) was only running about 20MBS and the 82579V adapter Advanced properties tab was blank, so
I decided to uninstall the driver and do a reinstall. First the 19.5 driver, then the 17.2 from Gigabyte, then the 11.13 driver from the
install CD from Gigabyte. All report back: "Cannot install drivers. No Intel adapters are present in this computer."
EHumb
Let me revise that Title: "82579V not recognized by Intel PROWinx64.exe for Windows 7 64 bit."
If someone could point me to the correct INF for this application, I'll gladly install it manually. W7 does not list the 82579 as a available NIC option. This is an embedded application on the motherboard. The one I was trying to use is from here:https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18713&ProdId=3409&lang=eng&OSVersion=&DownloadType=Drivers&iid=4363&wapkw=network+adapter+driver+for+windows+7 Intel® Download Center
EHumb
OK, I fixed it.
Found all this out by reading the other Threads.
First, Uninstall the Intel Management Engine Driver. AFTER finding the correct Management Engine Driver for your Motherboard. I used this one: https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22092&lang=eng&OSVersion=Windows%208%2C%2064-bit*&DownloadType=Drivers Intel® Download Center. and reinstalled it.
Now, go to whomever made your motherboard and find your latest Intel LAN driver. In my case it was from Gigabyte and was the 17.2 driver from here: http://www.gigabyte.com/products/product-page.aspx?pid=4279&dl=1&RWD=0# driver GIGABYTE - Motherboard - Socket 1155 - GA-Z77X-UP5 TH (rev. 1.0) This may not be correct for your motherboard or chip set. Do your homework before you try a driver.)
After installing this driver the 82579 is happy. It change stripes during install. Linux says it is an "V". Windows calls it both a "V" and "LM".
This is in a dual boot Linux Mint 17 machine and Linux never seemed to have any issues with the 82579 other than being slower than Windows 7-64. I figured it had to be software since Linux was OK with it. Right now I would say that the recognition issue was MED related and the update corrected the issue except for one thing: https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18713&ProdId=3409&lang=eng&OSVersion=&DownloadType=Drivers&iid=4363&wapkw=network+adapter+driver+for+windows+7 Intel® Download Center This driver still says that no Intel adapters are present. The 17.2 driver was giving the same error before the MED update. I'll let you Intel guys figure that one out.
Best Regards
Ed Humble II
