Ethernet Products
4620 Discussions
82599 using SRIOV in KVM
Hello:
I get stuck in here. Last time I post a disscussion about SR-IOV using of 82599 in XEN. I get reply from some of you, but I still failed to succeed in making it work. Now I read another article succeed in make it working in KVM written by Waseem.
Now I do as the article said, but I stucked as well. The problem remained to be " not enough MMIO resources for SR-IOV error ". And I am very sure that I have enable all the settings in BIOS and kernel as well as msi after checking the enviroment again and again.
I will post the relative information of my machine here in the attachment.
io memory:
00000000-0000ffff : reserved
00010000-0009dbff : System RAM
0009dc00-0009ffff : reserved
000a0000-000bffff : Video RAM area
000c0000-000c7fff : Video ROM
000c8000-000c8fff : Adapter ROM
000c9000-000c9fff : Adapter ROM
000e0000-000fffff : reserved
000f0000-000fffff : System ROM
00100000-bf78ffff : System RAM
00400000-00812005 : Kernel code
00812006-00a3d007 : Kernel data
00ac5000-00bd18a3 : Kernel bss
02000000-09ffffff : Crash kernel
bf790000-bf79dfff : ACPI Tables
bf79e000-bf7cffff : ACPI Non-volatile Storage
bf7d0000-bf7dffff : reserved
bf7e0000-bf7ebfff : RAM buffer
bf7ec000-bfffffff : reserved
e0000000-efffffff : PCI MMCONFIG 0 [00-ff]
e0000000-efffffff : reserved
e0000000-efffffff : pnp 00:0e
f8cdc000-f8cdffff : 0000:80:16.7
f8cdc000-f8cdffff : ioatdma
f8ce0000-f8ce3fff : 0000:80:16.6
f8ce0000-f8ce3fff : ioatdma
f8ce4000-f8ce7fff : 0000:80:16.5
f8ce4000-f8ce7fff : ioatdma
f8ce8000-f8cebfff : 0000:80:16.4
f8ce8000-f8cebfff : ioatdma
f8cec000-f8ceffff : 0000:80:16.3
f8cec000-f8ceffff : ioatdma
f8cf0000-f8cf3fff : 0000:80:16.2
f8cf0000-f8cf3fff : ioatdma
f8cf4000-f8cf7fff : 0000:80:16.1
f8cf4000-f8cf7fff : ioatdma
f8cf8000-f8cfbfff : 0000:80:16.0
f8cf8000-f8cfbfff : ioatdma
f8cfe000-f8cfffff : pnp 00:11
f8d00000-f8ffffff : PCI Bus 0000:85
f8d80000-f8dfffff : 0000:85:00.1
f8e00000-f8e7ffff : 0000:85:00.1
f8e00000-f8e7ffff : ixgbe
f8ef8000-f8efbfff : 0000:85:00.1
f8ef8000-f8efbfff : ixgbe
f8efc000-f8efffff : 0000:85:00.0
f8efc000-f8efffff : ixgbe
f8f00000-f8f7ffff : 0000:85:00.0
f8f80000-f8ffffff : 0000:85:00.0
f8f80000-f8ffffff : ixgbe
f9000000-f9ffffff : PCI Bus 0000:07
f9000000-f9ffffff : 0000:07:04.0
fadd8000-fadd80ff : 0000:00:1f.3
fadda000-fadda3ff : 0000:00:1d.7
fadda000-fadda3ff : ehci_hcd
faddc000-faddffff : 0000:00:16.7
faddc000-faddffff : ioatdma
fade0000-fade3fff : 0000:00:16.6
fade0000-fade3fff : ioatdma
fade4000-fade7fff : 0000:00:16.5
fade4000-fade7fff : ioatdma
fade8000-fadebfff : 0000:00:16.4
fade8000-fadebfff : ioatdma
fadec000-fadeffff : 0000:00:16.3
fadec000-fadeffff : ioatdma
fadf0000-fadf3fff : 0000:00:16.2
fadf0000-fadf3fff : ioatdma
fadf4000-fadf7fff : 0000:00:16.1
fadf4000-fadf7fff : ioatdma
fadf8000-fadfbfff : 0000:00:16.0
fadf8000-fadfbfff : ioatdma
fadfc000-fadfc3ff : 0000:00:1a.7
fadfc000-fadfc3ff : ehci_hcd
fae00000-faffffff : PCI Bus 0000:01
fae00000-fae1ffff : 0000:01:00.0
fae20000-fae3ffff : 0000:01:00.0
fae40000-fae5ffff : 0000:01:00.1
fae60000-fae7ffff : 0000:01:00.1
faee0000-faefffff : 0000:01:00.1
faf00000-faf1ffff : 0000:01:00.1
faf00000-faf1ffff : igb
faf20000-faf3ffff : 0000:01:00.1
faf20000-faf3ffff : igb
faf98000-faf9bfff : 0000:01:00.1
faf98000-faf9bfff : igb
faf9c000-faf9ffff : 0000:01:00.0
faf9c000-faf9ffff : igb
fafa0000-fafbffff : 0000:01:00.0
fafc0000-fafdffff : 0000:01:00.0
fafc0000-fafdffff : igb
fafe0000-faffffff : 0000:01:00.0
fafe0000-faffffff : igb
fb000000-fbefffff : PCI Bus 0000:07
fb000000-fb7fffff : 0000:07:04.0
fbefc000-fbefffff : 0000:07:04.0
fec00000-fec00fff : IOAPIC 0
fec8a000-fec8afff : IOAPIC 1
fec8a000-fec8afff : 0000:00:13.0
fec9a000-fec9afff : IOAPIC 2
fec9a000-fec9afff : 0000:80:13.0
fed00000-fed003ff : HPET 0
fed1c000-fed1ffff : pnp 00:01
fed1c000-fed1ffff : pnp 00:0b
fed20000-fed3ffff : pnp 00:0b
fed40000-fed8ffff : pnp 00:0b
fee00000-fee00fff : Local APIC
fee00000-fee00fff : reserved
fee00000-fee00fff : pnp 00:0d
ffc00000-ffffffff : reserved
100000000-33fffffff : System RAM
lspci:
00:00.0 Host bridge: Intel Corporation 5520 I/O Hub to ESI Port (rev 22)
Subsystem: Super Micro Computer Inc Device 0400
Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- SERR-   Capabilities: [60] MSI: Enable- Count=1/2 Maskable+ 64bit-
Address: 00000000 Data: 0000
Masking: 00000000 Pending: 00000000
Capabilities: [90] Express (v2) Root Port (Slot-), MSI 00
DevCap: MaxPayload 128 bytes, PhantFunc 0, Latency L0s <64ns, L1 <1us<p>  ExtTag+ RBE+ FLReset-
DevCtl: Report err...
Patrick_K_Intel1
The problem you are having is either with your BIOS or your OS.
Have you tried using Red Hat 6.1 KVM? I know that some version of Red Hat 5.5 Xen and KVM had a bug in regards to the Intel 82599 10Gb Ethernet Controller.
I don't see where you indicated what platform and BIOS version you are using. Might be useful in letting people help you out.
Hello:
You can use key word dmidecode to find the information in what I have posted above. Beside my OS is redhat 6.0.
Patrick_K_Intel1
What is the actual Server you are using? What model # , BIOS revision etc.
I'll see what I can find out for you - as I've mentioned before, it is likely a BIOS issue.
this is old but I will post this information here so people will at least have a chance of seeing this.
1. first disable selinux
2. rmmod kvm_intel
3. rmmod kvm
4. modinfo kvm
5. there will be one parameter listed there
6. modprobe kvm allow_unsafe_assignable_interrupts=1
7. modprobe kvm_intel
this may work.
selinux can in some instances block the assignment, since it doesnt succeed, you see the error message.
the other issue that can cause this is, not all bios's have a full sriov implementation that includes the ability to remap interrupts.
so the kvm parameter is used to allow this to work.
