Dear All,
I'm using latest version of ixgbe , ixgbevf and want to use SR-IOV function with xt-520 T2(dualport),but when I try to load ixgbe driver with this command:
# modprobe ixgbe max_vfs=2,2
It seems that only first port of the card's VFs works,the problem is second port of the card's VFs didn't work, and I found some errors in /var/log messages:
Nov 8 14:56:54 12 kernel: ixgbe 0000:07:00.1: not enough MMIO resources for SR-IOV
Nov 8 14:56:54 12 kernel: ixgbe 0000:07:00.1: (unregistered net_device): Failed to enable PCI sriov: -12
Any help would be greatly appreciated.
below is the related information:
Server: R710
OS: centos6.3
NIC: X520-T2(dualport)
kernel: 2.6.32-279.14.1.el6.x86_64
BIOSVersion: 6.3.0(latest)
BIOS:Inter VT-d/SR-IOV(enabled)
ixgbe:3.11.33(latest)
ixgbevf:2.7.12(latest)
kernel boot parameters: kernel /vmlinuz-2.6.32-279.14.1.el6.x86_64 ro root=UUID=c81b679a-e223-4490-91c0-114af927f28c rd_NO_LUKS rd_NO_LVM LANG=en_US.UTF-8 rd_NO_MD quiet SYSFONT=latarcyrheb-sun16 rhgb crashkernel=128M KEYBOARDTYPE=pc KEYTABLE=us rd_NO_DM biosdevname=0 intel_iommu=on
/var/log/messages:
Nov 8 14:56:54 12 kernel: Intel(R) 10 Gigabit PCI Express Network Driver - version 3.11.33
Nov 8 14:56:54 12 kernel: Copyright (c) 1999-2012 Intel Corporation.
Nov 8 14:56:54 12 kernel: ixgbe 0000:07:00.0: PCI INT B -> GSI 50 (level, low) -> IRQ 50
Nov 8 14:56:54 12 kernel: ixgbe: I/O Virtualization (IOV) set to 2
Nov 8 14:56:54 12 kernel: ixgbe: 0000:07:00.0: ixgbe_check_options: FCoE Offload feature enabled
Nov 8 14:56:54 12 kernel: ixgbe 0000:07:00.0: (unregistered net_device): SR-IOV enabled with 2 VFs
Nov 8 14:56:54 12 kernel: ixgbe 0000:07:00.0: FCoE offload feature is not available. Disabling FCoE offload feature
Nov 8 14:56:54 12 kernel: ixgbe 0000:07:00.0: (PCI Express:5.0GT/s:Width x8) 68:05:ca:0c:7a:e2
Nov 8 14:56:54 12 kernel: ixgbe 0000:07:00.0: eth4: MAC: 2, PHY: 2, PBA No: G21371-003
Nov 8 14:56:54 12 kernel: ixgbe 0000:07:00.0: eth4: Enabled Features: RxQ: 1 TxQ: 1 LRO
Nov 8 14:56:54 12 kernel: ixgbe 0000:07:00.0: eth4: IOV: VF 0 is enabled mac 0E:15:B9:26:B3:7D
Nov 8 14:56:54 12 kernel: ixgbe 0000:07:00.0: eth4: IOV: VF 1 is enabled mac 32:69:2D:16:B9:40
Nov 8 14:56:54 12 kernel: ixgbe 0000:07:00.0: eth4: Intel(R) 10 Gigabit Network Connection
Nov 8 14:56:54 12 kernel: ixgbe 0000:07:00.1: PCI INT A -> GSI 40 (level, low) -> IRQ 40
Nov 8 14:56:54 12 kernel: ixgbe: 0000:07:00.1: ixgbe_check_options: FCoE Offload feature enabled
Nov 8 14:56:54 12 kernel: ixgbe 0000:07:00.1: FCoE offload feature is not available. Disabling FCoE offload feature
Nov 8 14:56:54 12 kernel: ixgbe 0000:07:00.1: (PCI Express:5.0GT/s:Width x8) 68:05:ca:0c:7a:e3
Nov 8 14:56:54 12 kernel: ixgbe 0000:07:00.1: eth5: MAC: 2, PHY: 2, PBA No: G21371-003
Nov 8 14:56:54 12 kernel: ixgbe 0000:07:00.1: eth5: Enabled Features: RxQ: 16 TxQ: 16 FdirHash RSC
Nov 8 14:56:54 12 kernel: ixgbe 0000:07:00.1: eth5: Intel(R) 10 Gigabit Network Connection
# dmesg |grep -E 'DMA|IOMMU'
ACPI: DMAR 00000000bf3b3668 001C0 (v01 DELL PE_SC3 00000001 DELL 00000001)
DMA 0x00000001 -> 0x00001000
DMA32 0x00001000 -> 0x00100000
DMA zone: 56 pages used for memmap
DMA zone: 102 pages reserved
DMA zone: 3839 pages, LIFO batch:0
DMA32 zone: 14280 pages used for memmap
DMA32 zone: 764849 pages, LIFO batch:31
Intel-IOMMU: enabled
DMAR: Host address width 40
DMAR: DRHD base: 0x000000fed90000 flags: 0x1
IOMMU fed90000: ver 1:0 cap c90780106f0462 ecap f020fe
DMAR: RMRR base: 0x000000bf4c8000 end: 0x000000bf4dffff
DMAR: RMRR base: 0x000000bf4b1000 end: 0x000000bf4bffff
DMAR: RMRR base: 0x000000bf4a1000 end: 0x000000bf4a1fff
DMAR: RMRR base: 0x000000bf4a3000 end: 0x000000bf4a3fff
DMAR: RMRR base: 0x000000bf4a5000 end: 0x000000bf4a5fff
DMAR: RMRR base: 0x000000bf4a7000 end: 0x000000bf4a7fff
DMAR: RMRR base: 0x000000bf4c0000 end: 0x000000bf4c0fff
DMAR: RMRR base: 0x000000bf4c2000 end: 0x000000bf4c2fff
DMAR: ATSR flags: 0x0
DMAR: Device scope device [0000:00:1a.02] not found
DMAR: Device scope device [0000:00:1d.02] not found
IOMMU 0xfed90000: using Queued invalidation
IOMMU: Setting RMRR:
IOMMU: Setting identity map for device 0000:00:1d.7 [0xbf4c2000 - 0xbf4c3000]
IOMMU: Setting identity map for device 0000:00:1a.7 [0xbf4c0000 - 0xbf4c1000]
IOMMU: Setting identity map for device 0000:00:1d.1 [0xbf4a7000 - 0xbf4a8000]
IOMMU: Setting identity map for device 0000:00:1d.0 [0xbf4a5000 - 0xbf4a6000]
IOMMU: Setting identity map for device 0000:00:1a.1 [0xbf4a3000 - 0xbf4a4000]
IOMMU: Setting identity map for device 0000:00:1a.0 [0xbf4a1000 - 0xbf4a2000]
IOMMU: Setting identity map for device 0000:00:1a.0 [0xbf4b1000 - 0xbf4c0000]
IOMMU: Setting identity map for device 0000:00:1a.1 [0xbf4b1000 - 0xbf4c0000]
IOMMU: Setting identity map for device 0000:00:1d.0 [0xbf4b1000 - 0xbf4c0000]
IOMMU: Setting identity map for device 0000:00:1d.1 [0xbf4b1000 - 0xbf4c0000]
IOMMU: Setting identity map for device 0000:00:1a.7 [0xbf4c8000 - 0xbf4e0000]
IOMMU: Setting identity map for device 0000:00:1d.7 [0xbf4c8000 - 0xbf4e0000]
IOMMU: Prepare 0-16MiB unity mapping for LPC
IOMMU: Setting identity map for device 0000:00:1f.0 [0x0 - 0x1000000]
PCI-DMA: Intel(R) Virtualization Technology for Directed I/O
ata1: SATA max UDMA/13...
Thanx for coming to our forum and using Inel Ethernet.
Generally whenever we hear about lack of MMIO space, it is almost always the BIOS. I've done lots of SR-IOV on R710's and Intel 82599 10GbE devices.
You seem to have all the latest goodies - PF and VF driver.
The only variable in here that I've not used is your OS. I've never touched centos. Can you try install RHEL 6.2 and give it a try? Let's remove all unknown variable and see if we can figure it out.
- Patrick
