Ethernet Products
5821 Discussions
A question about Ethernet Controller XL710
efu2
A question about Ethernet Controller XL710 ,witch not expressed clearly in Datasheet:where is the L2tags removed from packet? Before Internal Switch,or after Internal Switch and before Receive Filters,or after Receive Filters? If the L2tags not removed, can the hash filter get input set correctly as no tag packet? For example, accoding to a packet with no L2tags, the hash filter can get the IP header follow the ethernet header. if a packet with L2tags between IP headert and ethernet header, can the hash filter correctly get the IP header ?
VincentT_T_Intel
Hi sofardware, i'm currently checking your question, will share info as soon as possible.
regards,
vince
VincentT_T_Intel
regards,
vince
efu2
Hi vince_intel,
Thank you for your reply. I have been waited your response for my questions.I wish you will give it in the very nearly future.
regards,
sofardware
