A question about Ethernet Controller XL710 ,witch not expressed clearly in Datasheet:where is the L2tags removed from packet? Before Internal Switch,or after Internal Switch and before Receive Filters,or after Receive Filters? If the L2tags not removed, can the hash filter get input set correctly as no tag packet? For example, accoding to a packet with no L2tags, the hash filter can get the IP header follow the ethernet header. if a packet with L2tags between IP headert and ethernet header, can the hash filter correctly get the IP header ?
Hi sofardware, currently checking your questions, will update this thread as soon as possible.
regards,
Vince
Hi Sofardware,
You may refer to this spec update for the information.
https://www-ssl.intel.com/content/www/us/en/embedded/products/networking/xl710-10-40-controller-spec... https://www-ssl.intel.com/content/www/us/en/embedded/products/networking/xl710-10-40-controller-spec...
Let me know if the information answered your question.
thanks,
wb
