Ethernet Products
5585 Discussions
ASUS VANGUARD B85 mainboard onboard ethercard Intel® I217V and intel I350-T4 PCI-E ethercard can be used together?
Personal desktop PC, ASUS VANGUARD B85 mainboard onboard ethercard Intel® I217V, now need to install a intel I350-T4 PCI-E 4 port gigabit ethercard, run Windows Server 2012 R2 operating system. Ask: they can be used together?
https://downloadcenter.intel.com/download/25442/Network-Adapter-Driver-for-Windows-Server-2012-R2- https://downloadcenter.intel.com/download/25442/Network-Adapter-Driver-for-Windows-Server-2012-R2- This is intel I350-T4 for Windows Server 2012 R2 operating system of the driver? Among the following description:
NOTE: The following devices do not have driver or software support for Windows Server 2012 R2:
- Intel® Ethernet Connection I217-V
- Intel® Ethernet Connection I218-V
- Intel® 82579V Gigabit Ethernet PHY
Does this mean that after the installation is complete, i mainboard onboard ethercard Intel® I217V will invalid?
st4
New Contributor III
Hi bobyuan,
There is no Windows 2012 R2 driver for I217V ethernet controller, it will not be properly detected on your system. It is recommended you check with Asus support if both can be installed together on their system, Normally the system vendor has tested list of network adapters to check if the network adapter is compatbiel on the system.
wb
Thank very much!
I found the solution to the problem. Can modify the i217V driver hardware ID, enter the \PRO1000\Winx64\NDIS64 directory, find the e1d64x64.inf file...
Another method is relatively simpler, can directly to install i217-LM drive...
st4
New Contributor III
Hi bobyuan_007,
Thank you for sharing the solution.
rgds,
wb
