Ethernet Products
4876 Discussions
About VF multiple queue
TWang25
I have a Dual-port Intel 82599 NIC.
My testbed is Ubuntu 14.04, ixgbe driver 5.2.3, ixgbevf 4.2.1.
I initialize one VF by executing
echo 1 >> /sys/bus/pci/devices/0000\:06\:00.0/sriov_numvfs
However, the number of queue pair attached to this VF is only 1, as shown in the dmesg
[ 727.882194] ixgbevf 0000:06:10.0: Multiqueue Disabled: Rx Queue count = 1, Tx Queue count = 1
This is may be not consistent with the Intel 82599 data sheet, which shows a pool of queue pairs (e.g., 8, 4 or 2) is assigned to the VF interface.
My question is how to configure VF multiple queue correctly?
HI Wtao000,
Thank you for posting at Wired Communities. I will check on this.
sharon
Hi Wtao000,
Please try using below command to add the queue, as stated on page 11 at
https://www.intel.com/content/dam/www/public/us/en/documents/technology-briefs/xl710-sr-iov-config-guide-gbe-linux-brief.pdf
example:
# modprobe i40e max_vfs=4,4
sharon
TWang25
Sorry, this may still not work.
My NIC controller is 82599. I have run "modprobe ixgbe max_vfs=4,4".
It still can not work.
Hi Wtao000,
Thank you for the update. Let me further check.
sharon
TWang25
Hi, Sharon
so, any further updates now?
Best,
Tao
Hi Wtao000,
The latest 82599 physical function and virtual function drivers can support multi queue feature. Can you help clarify if the VF is being assigned to a VM and how many vCPU are assigned to the VM?
Sharon
Hi Wtao000,
Please feel free to provide the information for us to better assist you.
Sharon
