Ethernet Products
5821 Discussions
About programming from I 210 to blank flash.
YKiku
It is a question when programming from I210 to a blank flash.
When programm to Flash of Blank using EepromAccessTool, "NVM_SI (pin12)" must be "pull down(Low)" with HW?
Using the "Flash of Blank using EepromAccessTool",
Is it possible to program from Blank Flash?
Tool Ver.:eepromaccesstool-0-7-6
Daniel_D_Intel1
Hello Ykiku, Thank you for posting in Intel Ethernet Communities. Please refer to the following thread, as it will be helpful: https://forums.intel.com/s/question/0D50P00004905mESAQ/i210-with-an-external-flash? If you have further questions about programming the I210, please refer to the Embedded Community. If you have any other questions relating to the Ethernet Controller, please let us know. https://forums.intel.com/s/topic/0TO0P00000018NIWAY/embedded-products? Best regards, Daniel D Intel Customer Support Under Contract to Intel Corporation
Daniel_D_Intel1
Hello Ykiku, Please let us know if you were able to find a solution in the Embedded Community. If you have any other questions please do not hesitate to ask. Best regards, Daniel D Intel Customer Support Under Contract to Intel Corporation
YKiku
Hello Daniel-san
Thank you for your reply.
I am asking customer support directly now.
Thank you.
Daniel_D_Intel1
Hello Ykiku, Thank you for the reply. It seems our colleagues have referred you to the Resource and Design Center. Hopefully the design team can provide a solution. Let us know if you have any other questions. Best regards, Daniel D Intel Customer Support Under Contract to Intel Corporation
