Ethernet Products
5744 Discussions
About the Intel® Ethernet Controller I225-V
evanxzxx
Device is mini PC ,Network adapters is 1225-V
Then i install the Kylin v10senior server system ,it seems like base on Redhat 8.0
Use command ifconfig,it cannot found the created nic
i need an available patch and update in it
<linux version 4.19.90-25.2.v2101.gf01.ky10.x86_64>
IntelSupport
Community Manager
Hi evanxzxx,
Good day,
Thank you for your reply.
I am glad that the link provided help in clarifying some things.
I would like to ask if you have further questions or clarifications regarding this case.
Else if none, may I proceed to close the case of 06013664?
Feel free to contact us should you need any further assistance, and we will be more than glad to continue assisting you.
Nurhayati
Intel® Customer Support
IntelSupport
Community Manager
Thank you for posting on the Intel️® communities.
Regarding your issue - Created NIC cannot be found using if config command as igc standalone / out-of-tree driver is unsupported when using with Intel® Ethernet Controller I225-V for Red hat 8.0.
We would suggest you to refer to link below:
https://www.intel.com/content/www/us/en/support/articles/000055236/ethernet-products/gigabit-ethernet-controllers-up-to-2-5gbe.html
Please let us know the outcome after you done it and will be happy to assist if any other troubleshooting required for this issue.
Nurhayati Ibrahim
IntelSupport
Community Manager
Hello evanxzxx,
Regarding your case number 06013664, we are following up to find out if you were able to complete the actions, we previously recommended.
Please reply to this thread to confirm, so we can continue helping with a resolution. Looking forward to receiving your reply!
Thank You & Regards,
Nurhayati
evanxzxx
Thanks a lot in your help!!!
I had refered to link which you provided.The trouble thing is Network-Manager driver cannot be recognized in Kylin OS.I guess it need compile the kernel drivers code,then i use yum command to update igc resource.But i have no driver code about the 1225-V.Maybe the another method is to use USB Wi-Fi Adapters and then compile the kernel driver code on kyrin OS.Afterthat I will try it.
IntelSupport
Community Manager
Hi evanxzxx,
Good day,
Nurhayati
IntelSupport
Community Manager
Hello evanxzxx,
Good day,
This message is to inform you about the thread closure.
Once the thread is closed, it will no longer be monitored by Intel. Kindly submit a new thread should you need further assistance. We will be more than glad to continue assisting you.
Nurhayati
