Ethernet Products
5608 Discussions
Access Error after NVMUpdatePackage on X710-DA2 .
SChan72
Hi ,
We upgraded firmware of X710-DA2 (EtrackID was added into .cfg file ) and after that card shows access error , how to recover it ?
Server : ProLiant DL380 Gen10
OS : 14.04.1-Ubuntu , 3.16.0-77-generic (our internal requirement )
NICs : HPE Ethernet 10Gb 2-port 562FLR-SFP+ Adapter (Embedded )
Intel(R) Ethernet Converged Network Adapter X710 (Field Replacable)
What we have done :
1. Upgraded driver to 2.4.10
2. Tried NVMUpdatePackage , it displayed update not available.
3. After looking at couple of forum threads for same issue ,we added EtrackID to the nvmupdate.cfg and tried again , upgrade failed with error .
4. After system reboot , ports are not showing in ifconfig .
Vendor ID IS : 8086 , DEVID is : 5172 , used in PCIe 3.0, x8
sudo lspci | egrep -i --color 'network|ethernet'
02:00.0 Ethernet controller: Broadcom Corporation NetXtreme BCM5719 Gigabit Ethernet PCIe (rev 01)
02:00.1 Ethernet controller: Broadcom Corporation NetXtreme BCM5719 Gigabit Ethernet PCIe (rev 01)
02:00.2 Ethernet controller: Broadcom Corporation NetXtreme BCM5719 Gigabit Ethernet PCIe (rev 01)
02:00.3 Ethernet controller: Broadcom Corporation NetXtreme BCM5719 Gigabit Ethernet PCIe (rev 01)
13:00.0 Ethernet controller: Intel Corporation Ethernet 10G 2P X710 Adapter (rev 01)
13:00.1 Ethernet controller: Intel Corporation Ethernet 10G 2P X710 Adapter (rev 01)
5d:00.0 Ethernet controller: Intel Corporation Ethernet 10G 2P X710 Adapter (rev 01)
5d:00.1 Ethernet controller: Intel Corporation Ethernet 10G 2P X710 Adapter (rev 01)
admin@versa-flexvnf: ~] # ethtool -i eth4
driver: i40e
version: 0.4.10-k <<<< First updated Driver .</span>
firmware-version: f5.60 a1.5 n05.60 e800033b1 <<<<</span>
bus-info: 0000:5d:00.1
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: no
[admin@versa-flexvnf: ~] # sudo ethtool -i eth4
driver: i40e
version: 2.4.10 <<<<<<< Driver update ok </span>
firmware-version: 5.60 0x800033b1 1.1752.0 <<<<<<<<</span>
bus-info: 0000:5d:00.0
supports-test: yes
supports-priv-flags: yes
[admin@versa-flexvnf: Linux_x64] # sudo ./nvmupdate64e
Intel(R) Ethernet NVM Update Tool
NVMUpdate version 1.30.22.3
Copyright (C) 2013 - 2017 Intel Corporation.
WARNING: To avoid damage to your device, do not stop the update or reboot or power off the system during this update.
Inventory in progress. Please wait [***|......]
Num Description Ver. DevId S:B Status
<span style="font-famil...
Hi Saichandra,
Thank you for posting in Wired Ethernet Communities. There is the possibility your X710 adapter is an OEM version, thus even by changing the Etrack ID in the config file this will not work. Does this X710 adapter come with the HP* Proliant system? Based on the firmware version 4.65 this is not the firmware for Intel retail NIC, for OEM X710, please contact the OEM NIC vendor for the customized firmware update that is suitable for your X710 adapter.
Please feel free to update me.
Sharon T
Intel Customer Support
Agent under contract to Intel
SChan72
Hi Sharon T ,
Yes , HPE Ethernet 10Gb 2-port 562FLR-SFP+ Adapter came with HP Server
Intel(R) Ethernet Converged Network Adapter X710 purchased separately from third party ( DELL ) , Even this EtrackID is not there in nvmupdate.cfg file , do we need to contact DELL for this upgrade too ?
EtrackID of other card is :: 80001866
[admin@versa-flexvnf: Linux_x64] # sudo ethtool -i eth6
[sudo] password for admin:
driver: i40e
version: 2.4.10
firmware-version: 4.41 0x80001866 16.5.20
bus-info: 0000:13:00.0
supports-test: yes
01) Intel(R) Ethernet Converged Network 4.65 1572 00:019 Update not
Adapter X710 available
02) HPE Ethernet 10Gb 2-port 562FLR-SFP+ 5.96 1572 00:093 Update not
Adapter available
Thanks ,
Sai Chandra .
Hi Saichandra,
Thank you for the reply and information. You need to contact Dell* the OEM NIC vendor for the firmware that is customized for your OEM NIC. Hope this clarified.
Sharon T
Hi Saichandra,
Please let us know if you have contacted Dell* support, you need to contact them for the customized firmware that is compatible to the NIC.
Sharon T
SChan72
Hi Sharon T ,
Yes , we are following up with the vendor .
Sai Chandra .
Hi Saichandra,
Thank you for the update and good to know that you are contacting Dell*, hope you will be able to avail the firmware soon. In case you have other inquiries, please feel free to contact us.
Sharon T
