As the PROset adapter configuration does not allow you to create VLANs, I've tried with with the following powershell commands as administrator:
PS C:\Users\username> Get-IntelNetAdapter
Location Name ConnectionName LinkStatus
0:25:0:0 Intel(R) Ethernet Connection I217-LM Ethernet 1,00 Gbps ...
PS C:\Users\username> Add-IntelNetVLAN -ParentName "Intel(R) Ethernet Connection I217-LM" -VLANID 0,196
Add-IntelNetVLAN : Failed to add one or more of the specified VLAN IDs.
At line:1 char:1
+ Add-IntelNetVLAN -ParentName "Intel(R) Ethernet Connection I217-LM" - ...
+ CategoryInfo : InvalidOperation: (IANet_PhysicalE...e = "username-HP2"):CimInstance) [Add-IntelNetVLAN], Ex
ception
+ FullyQualifiedErrorId : Error executing cmdlet.,Intel.PowerShell.Network.VLAN.AddIntelNetVlan
This disables the adapter, but does not create a VLAN interface. What am I doing wrong. Even tried this in safe mode, with no success as well.
- « Previous
- 1
- 2
- Next »
Sorry for the late response, but I share the same concerns/opinion as @DDupr .
23.5 is the first version that supports 1809 per Intel's documentation (unless you have another reason for me to test it?) and a fresh install isn't an option as this is my daily driver in a office environment.
I have the same problem:
PS C:\WINDOWS\system32> Add-IntelNetVLAN
cmdlet Add-IntelNetVLAN at command pipeline position 1
Supply values for the following parameters:
ParentName[0]: Intel(R) Ethernet Connection (2) I218-V
ParentName[1]:
VLANID[0]: 0
VLANID[1]: 211
VLANID[2]: 212
VLANID[3]: 221
VLANID[4]: 222
VLANID[5]: 223
VLANID[6]: 224
VLANID[7]:
At line:1 char:1
+ Add-IntelNetVLAN
+ CategoryInfo : InvalidOperation: (IANet_PhysicalE...TRYK-KOMPUTER"):CimInstance) [Add-IntelNetVLAN], Exception
I have Asus Z97-PRO GAMING Mobo with I218-V.
It disables my ethernet connection then hangs for 1-2mins and puts that error.
Why we can't add VLANs traditionally, like we used to in the device manager?
Hello
intel i219-lm, win 10 17763.195, exactly same problem here.
Need solution asap. =(
Hello Snevas,
We will continue to investigate solutions to this issue and update you soon. Let us know if you have any other questions.
@Mayestro_PW Intel PROSet for Windows device manager will no longer be supported by Windows 10 1809 (and later) and Windows Server 2019.
Daniel D
Intel Customer Support
Is there an update on this? We are having the same issue. We want to create multiple vlan interfaces on a Intel I219-LM adapter.
Sven
Hy @ all!
I have a big Problem to adding a second VLAN to my NIC.....i updated from Windows 7 to Windows 10 and till i made this i cannot see my second virtual NIC.
Now I have seen in the Internet that here are some Driver Problems for the extended Network Setting. ( i cant get the VLAN Tab for configuration)
I tried it with PowerShell but than i get Problems with Drivers when i like to use the command:
Add-IntelNetVLAN -ParentName "Intel(R) 82579LM Gigabit Network Connection" -VLANID 19
Error: The selected Adapter is an Intel device, but has no Intel Driver installed and can not execute this command!
But when i like to update my Driver Windows says: you have the perfect Driver.....
What can i do please can someone help me.....
I scanned my System look at the file (ws-bennik)
Thx to all
If anyone could help me it would be very nice =)
Cheers
Patrick R.
- « Previous
- 1
- 2
- Next »
