Ethernet Products
5530 Discussions
[Agilex]: igb probe failed with error -13
raju1421
Dear Intel Team,
We are currently encountering an issue with our Intel Agilex 7 SoC Development Kit connected to an I210-T1 Ethernet Server Adapter during the Linux boot-up process.
The error message we are encountering is as follows:
[ 1.384867] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.390565] igb 0000:01:00.0: enabling device (0000 -> 0002)
[ 1.403729] igb: probe of 0000:01:00.0 failed with error -13
We kindly request your guidance and support to help us resolve this issue.
Thanks & Regards
Satrasala Raju
IntelSupport
Community Manager
Hello raju1421,
It seems like there is a compiler mismatch.
Ensure that the kernel source headers you are using match the kernel version running on your target system. If there is a mismatch, it can lead to compilation errors.
Did you check the information and the support on The Yocto Project as well?
Kindly let us know if you have any questions.
Hayat
Intel Customer Support
IntelSupport
Community Manager
Hello raju1421,
Thank you for posting in Intel Community.
Can we confirm that you have the latest kernel and drivers up to date?
If the driver is not up to date, please check and update your driver here: Intel® Ethernet Adapter Complete Driver Pack
Can you please specify the OS you are using.
Can I also get an output for the command:
dmesg | grep igb
modprobe -r igb
modprobe igb
lspci -v
Hayat
raju1421
Thank you for your response.
We are utilizing files from Rocketboards Agilex PCIe Root Port Documentation.
https://www.rocketboards.org/foswiki/Documentation/AgilexPcieRootPort
Below are the details
root@agilexfm61:~# uname -r
5.15.90-156414-g0b11acba1131-dirty
root@agilexfm61:~# cat /proc/version
Linux version 5.15.90-156414-g0b11acba1131-dirty (root@Precision-3650) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the Arm Architecture 11.2-2022.02 (arm-11.14)) 11.2.1 20220111, GNU ld (GNU Toolchain for the Arm Architecture 11.2-2022.02 (arm-11.14)) 2.37.20220122) #1 SMP PREEMPT Fri Nov 17 14:05:48 IST 2023
root@agilexfm61:~# dmesg | grep igb
[ 1.379324] igb: Intel(R) Gigabit Ethernet Network Driver
[ 1.384710] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.390404] igb 0000:01:00.0: enabling device (0000 -> 0002)
[ 1.403556] igb: probe of 0000:01:00.0 failed with error -13
[ 1.409292] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[ 1.415549] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
root@agilexfm61:~# modprobe -r igb
modprobe: FATAL: Module igb not found.
root@agilexfm61:~# modprobe igb
modprobe: FATAL: Module igb not found in directory /lib/modules/5.15.90-156414-g0b11acba1131-dirty
root@agilexfm61:~# cat /etc/os-release
ID=poky
NAME="Poky (Yocto Project Reference Distro)"
VERSION="4.1.3 (langdale)"
VERSION_ID=4.1.3
PRETTY_NAME="Poky (Yocto Project Reference Distro) 4.1.3 (langdale)"
DISTRO_CODENAME="langdale"
Thanks & Regards
Satrasala Raju
IntelSupport
Community Manager
Hello raju1421,
According to The Yocto Project here, it seems like you are currently using the Langdale which has already been EOL.
I would suggest you to consider reaching out to the Yocto Project community or support channels for assistance. They may be able to provide guidance on resolving module-related issues specific to Yocto Project.
Hayat
raju1421
After downloading the latest drivers, we also obtained the ARM cross-compiler from the previously mentioned link.
However, we are encountering errors during  compilation process.
filtering include/net/flow_keys.h out
filtering include/linux/jump_label_type.h out
*** The target kernel has CONFIG_MODULE_SIG_ALL enabled, but
*** the signing key cannot be found. Module signing has been
*** disabled for this build.
make[1]: Entering directory '/usr/src/linux-headers-6.2.0-34-generic'
warning: the compiler differs from the one used to build the kernel
The kernel was built by: x86_64-linux-gnu-gcc-11 (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0
You are using:
CC [M] /src/igb_main.o
/bin/sh: line 1: aarch64-none-linux-gnu-gcc-11: command not found
make: *** [Makefile:87: default] Error 2
Thanks & Regards
Satrasala Raju
IntelSupport
Community Manager
Hello raju1421,
Hayat
IntelSupport
Community Manager
Hello raju1421,
Regarding your thread, we are following up to find out if you were able to complete the actions, we previously recommended.
Please reply to this thread to confirm, so we can continue helping with a resolution. Looking forward to receiving your reply!
Else if none, kindly confirm the thread closure.
Thank you.
Hayat
Intel® Customer Support
raju1421
Hi
Thank you,
Close the Thread.
Satrasala Raju
IntelSupport
Community Manager
Hi raju1421,
Thank you for your confirmation.
We will proceed for the thread closure.
Once the thread is closed, it will no longer be monitored by Intel
Kindly reopen a new thread if you have further questions.
Hayat
