Ethernet Products
5720 Discussions
Are FTLX1471D3BCV-IT and FTLX1471D3BCVI31 Part Numbers Compatible with Intel X520 DP 10Gb DA / SFP + Cards?
DBuss1
​This link https://www.intel.ca/content/www/ca/fr/support/articles/000005528/network-and-io/ethernet-products.html said that I must use the tranceiver E10GSFPLR FTLX1471D3BCVI31.
Many dealers offer part numbers FTLX1471D3BCV-IT and FTLX1471D3BCVI31 for the same product. Are these part numbers compatible with X520 cards?
Caguicla_Intel
Hello DBuss1,
Please provide the markings of your adapter. This would help us identify if you are using an OEM or retail version of Intel Ethernet Adapter. Kindly refer to the link below on where to find the PBA of the adapter. It is a 6-digit number located at the last part of the serial number.
https://www.intel.com/content/www/us/en/support/articles/000007022/network-and-io/ethernet-products.html
Crisselle C
Intel Customer Support
A Contingent Worker at Intel
DBuss1
​The server is in a remote site. I ran a scan with the executable Intel ssu. I'm attaching the scan file. Are you able to identify the required modules from this information?
Caguicla_Intel
Hello DBuss1,
Thank you for the reply
Please allow us to check on the provided logs. Rest assured that we will provide an update within 3 business days.
Hoping for your patience.
Crisselle C
Caguicla_Intel
Hello DBuss1,
Thank you for the patience on this matter.
Upon checking the provided SSU log, you are using a Dell OEM version of Intel Ethernet Adapter. For OEM version, we would suggest to contact Dell to double check the validated transceiver as they might have customized drivers and software to enable or alter features of their adapter.
However, for Retail adapter, mentioned on the link you have provided,
Some 1000BASE-T and 1000BASE-SX modules work with Intel® Ethernet Converged Network Adapter X520 series. The table lists tested modules. Other similar modules may work but have not been tested.
Let us know if you have additional questions and clarifications on this request.
Crisselle C
Caguicla_Intel
Hello DBuss1,
Good day!
We'd like to check if you have additional questions and clarifications on this query. In case you do, please let us know and we will be glad to be of help.
Hoping to hear form you.
Crisselle C
DBuss1
It will be fine. I will check with Dell support Thank you! Daniel
Caguicla_Intel
Hello DBuss1,
You are welcome.
Please let us know if you want to keep this request open or should we proceed with closure.
Crisselle C
DBuss1
Hi Crisselle, Close this case for me please. Thanks! DBuss1
Caguicla_Intel
Hello DBuss1,
Thank you for the reply.
Should you have any other assistance needed from Intel Ethernet team, please do not hesitate to post a new question and we will be glad to be of help.
Have a great day!
Crisselle C
