Hello All,
I am attempting to use the Triple Speed Ethernet core on an Arria 10 GX development board but I am unsure what settings to use to make it work. I tired to use the RJ-45 connector on the board but there is no high speed serial interface clock pin in the same I/O bank as the pins. I also tried to use the SFP+ cage but I don't see any data movement in SignalTap. Any advice or suggestions in this area would be appreciated.Link Copied
Try to start with a reference design if you can find one. There are several TSE reference designs out there but I'm not sure about Arria 10.
Well, I did a quick google search and found this: https://www.altera.com/en_us/pdfs/literature/an/an744.pdf This may get you started. Good luck.- Mark as New
Any decent development board will have example projects for everything on the board. Download the CD from the maker's web site.
