Ethernet Products
5523 Discussions
Asus Maximus VII Formula W/ On-Board Intel I218V won't connect at 1gbps
DToll1
I just built this computer yesterday and have updated all BIOS and Drivers along the Motherboard I am connecting to a linksys wrt 1900AC with a Cat6 cable that was used on my older computer(connecting at 1Gbps) I cannot think of anything else and I do not have any other NIC cards to install in a PCI slot to find out if it's just the onboard nic. I have set the card to auto-negotiation and 100.00 Mbps full duplex is all I get I tried to force the 1Gbps connection and windows tells me that I have a cable unplugged until I change it back. Jumbo Packets are disabled. I have been trying to find anyone with the same problem online and I have seen a couple of posts not related to this specific card.
Thanks in advance for any help that you provide.
st4
New Contributor III
Hi Starvin_Marvin,
Can you check if can force the gigabit port speed on the Linksys WRT 1900AC router to 1 Gbps? I checked on the tech spec, this router has 4x Gigabit LAN port. Just to double check if you have test each port to isolate the issue?
thanks,
wb
