Ethernet Products
5716 Discussions
Backplane communication with I210 IS
MGlas
Hello together,
I want to realize a backplane communication with two I210 IS Ethernet controller. My intention is to use SGMII or SERDES interface.
Is there an application note available how to realize such an application?
Thanks in advance,
Maximilian
Hi GlaserMaximilian,
Thank you for posting in Wired Communities. Can you share more information about the backplane communication? Are you referring to you plan to connect I210 IS ethernet controller to SGMII or SERDES interface ?
Sharon
MGlas
Hi Sharon,
I have to realize a communication of two processors via. Ethernet. The whole system is designed on only one circuit card. From upper software point of view the system should react like two separated processor systems which are connected via LAN cable. I tried to show it in a small sketch below.
Maximilian
Thank you for the clarification. I will have to check on this.
Sharon
Please be informed you may post your inquiry at https://embedded.communities.intel.com/community/en for them to further assist you.
Sharon
