Ethernet Products
5163 Discussions
Bad impressions of the network card after driver update.
JKiss2
I use original network card Intel 82574L (EXPI9301CTBLK). After the upgrade, with the built-in "Windows 7 x64" driver 11.0.5.22 to the last 12.7.28.0 there are delays in downloading web pages. There is a general slowdown. Why are there new drivers slow down? After roll back to version 11.0.5.22 everything becomes normal.
PS And in the driver confused modes FullDuplex (Half) and HalfDuplex (Full).
st4
New Contributor III
Hi John Kiss,
Thank you for the post. I am sorry to hear what happened , there are many factors that affects slow down. Have you tried changing the cable, or did you made any changes on the system?
For the transmission mode, by default Gigabit speed is in full duplex mode or you can use autonegotiation.
rgds,
wb
JKiss2
On the cable there is no problem. Ping 1ms, no packet loss. On page load delay only affects the driver update.
PS: The rate used 100 Mbps. Enables 100 Mbps Half Duplex and download speed becomes 100 Mbps. With mode 100 Mbps Full Duplex - 8-10 Mbps maximum for downloading. How is this possible? The provider uses a switch D-Link DES-3526. When I use the Realtek network card is no such problem.
st4
New Contributor III
Hi John Kiss,
Please make sure to use autonegotiation or gigabit speed.
Make sure the setting on the switch is gigabit or autonegotion is the switch is manageable.
rgds,
wb
JKiss2
And what to do with the delay in loading pages with updated drivers? Stay on older drivers?
st4
New Contributor III
Hi John Kiss,
Did you try re-installing the driver? Have you had another system (in case you have) for you to test if the same issue will occur on the CT desktop adapter?
wb
JKiss2
Of course I reinstalled. Many times. How else would I know about this problem? Another PC is not available. The problem in the driver. With the old driver 11.0.5.22 works perfectly. Maybe you need any more information? Ask.
st4
New Contributor III
Hi John Kiss,
Can you share what is the website where you download the driver?
thanks,
wb
st4
New Contributor III
Hi John,
Thanks for sharing the link. Will check on this.
rgds,
wb
st4
New Contributor III
Hi John,
Good day. We did some testing and sharing here our simulation result. So far we did not encounter the slow page load problem. Please see detail below:
Driver version: 12.7.28.0
Advance setting in the NIC:
Flow control - Rx & Tx Enabled
InterruptModeration - Enabled
IPchecksumoffload IPv4 - Rx & Tx Enabled
JumboPacket - Disabled
Large send offload IPv4 - Enabled
Large send offload IPv6 - Enabled
Priority & VLAN - enabled
Received buffers - 256
Receive Side scaling - enabled
speed and duplex - Auto negotiation
TCP checksum offload IPv4 - Enabled
TCP checksum offload IPv6 - Enabled
UDP checksum offload IPv4 - Enabled
UDP checksum offload IPv6 - Enabled
transmit buffers - 512
Wake on magic packet - enabled
wake on pattern match - enabled
adaptive inter-frame spacing - disabled
enabled pme - disabled
interrupt moderate rate - adaptive
log link event - enabled
gigabit master slave mode - auto detect
local administered address - none
receive side scaling queues - 1
reduce speed on power down - 1
wait for link - auto detect
wake on link settings - disabled
Please try the following:
1)Use older driver version 20.1, 20.2 to see if this will make any difference:
version 20.2
https://downloadcenter.intel.com/download/25242/Network-Adapter-Driver-for-Windows-7-?product=50395 https://downloadcenter.intel.com/download/25242/Network-Adapter-Driver-for-Windows-7-?product=50395
version 20.1
https://downloadcenter.intel.com/download/25112/Network-Adapter-Driver-for-Windows-7-?product=50395 https://downloadcenter.intel.com/download/25112/Network-Adapter-Driver-for-Windows-7-?product=50395
2)Disable onboard NIC to check if there's improvement on CT adapter
3) Can you please provide the steps on how you encountered the "page load slow" issue
4) Please download and run the SSU to provide me the xml file. You may attach the log file in the post
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
wb
JKiss2
I did not mean slow loading pages. A mean delay before the page loads. With the driver e1q60x64 - 11.0.5.22 page loaded immediately. Above this version there is a delay. Disabling onboard NIC does not help. Try to use the older driver. I send it to you. https://onedrive.live.com/?authkey=!AMtaD92cvvIDH3U&id=ED56934E6CD60822!414&cid=ED56934E6CD60822 https://onedrive.live.com/?authkey=!AMtaD92cvvIDH3U&id=ED56934E6CD60822!414&cid=ED56934E6CD60822
And then compare the work with the new version.
st4
New Contributor III
Hi John,
Thank you for the clarification. Does this issue occur if you are using a different browser?
Just to double check,
When you open the browser type in the URL, with version 11, the webpage would load immediately, but with the newer version the page will not load immediately as you mentioned, do you mind telling me like how many seconds is the delay?
rgds,
wb
JKiss2
Yes. Now you understood me correctly. I think the browser is not important. Because Windows 10 (Edge) with a new driver, too, have this problem. The delay may be from 1 to 3 seconds.
st4
New Contributor III
Hi John,
Thank you for the clarification. Will further check on this.
rgds,
wb
st4
New Contributor III
Hi John,
The SSU log shows there is no conflict between driver version 11 and 12. We are not able to replicate your
issue as we did not encounter the loading page issue. We use IE 11 and access Intel website and open another tab accessing another intel website, there was no mean delay.
Can you help provide the serial number of the CT desktop adatper? You can check on this website
about the location of the serial number
http://www.intel.com/content/www/us/en/support/network-and-i-o/ethernet-products/000007022.html http://www.intel.com/content/www/us/en/support/network-and-i-o/ethernet-products/000007022.html
It is three sets of alphanumeric e.g. 00xxxxxxxxxx xxxxx xxxxxx-xxx
wb
JKiss2
serial number 001B21C40743 291CR E46981-006
st4
New Contributor III
HI John,
Thank you for the information.
rgds,
wb
st4
New Contributor III
Hi John,
Good day. I would like to check with you if it is OK for you if we will replace your network adapter.
wb
