Ethernet Products
4539 Discussions
CVE-2015-2291 Intel Network Adapter Diagnostic Driver IOCTL DoS
JLang10
A vulnerability in iqvw32.sys and iqvw64e.sys drivers has been discovered in the Intel Network Adapter Driver. Intel Network Adapter Diagnostic Driver is prone to multiple local buffer-overflow vulnerabilities.
An attacker can exploit these issues to crash the affected application; denying service to legitimate users. Due to the nature of this issue, code-execution may be possible but this has not been confirmed.
Note: This issue was previously titled 'Intel Network Adapter Diagnostic Driver CVE-2015-2291 Multiple Remote Code Execution Vulnerabilities'. The title and technical details have been changed to better reflect the underlying component affected.
When will a vendor-supplied patch be available?
Joel
Allan_J_Intel1
I have moved your post to our Networking department
Allan.
st4
New Contributor III
Hi langejoel,
Thank you for bringing this matter to our attention. We will need to check on this.
rgds,
wb
JLang10
wb,
Any news about how to remediate this vulnerability? Thank you for looking into this.
Joel
JLang10
Thank you Mark, I will have our patch group test this solution out hopefully soon. When we see resolution I will post to the site and mark your solution as the Answer.
Thank you for responding to my second inquiry so soon.
jL
That download will not work on my HP servers.
Any other ideas/suggestions?
I have the latest and greatest NIC driver and firmware installed but still getting flagged with this vulnerability.
