Hi, I have been having a network problem with my new motherboard MSI H81M ECO, it uses an Intel I218-V. I use this new computer as a server for my home. Everything is working but after a while the NIC will stop working and when I go to the Network Connections on Windows 8.1 it says cable unplugged. I have to disable the device and reenable it to make it work, not the best solution for a home server.
I tried the latest driver from the MSI website and from Intel, tried 3 cables CAT 5e but nothing is working. Here is the XML from the event when it is disconnected:
- http://schemas.microsoft.com/win/2004/08/events/event http://schemas.microsoft.com/win/2004/08/events/event">
27
3
0
0x80000000000000
1864
System
Aristote
Intel(R) Ethernet Connection (2) I218-V
0000040002003000000000001B0004A00000000000000000000000000000000000000000000000001B0004A0
Hi gplaurin,
What is the Intel driver version you installed? You may tried check the latest version from https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=I218V Intel® Download Center
Have you contacted MSI support regarding this issue to check if there is any hardware issue.
thanks,
wb
