Ethernet Products
5780 Discussions
Cache memory of PCIe Intel i350?
EFrei2
How much cache memory has the PCIe Intel i350?
Mark_H_Intel
Hi Erick,
Is your question concerning the on-chip descriptor buffers for the receive and for the transmit? Or are you looking for other information?
Here is a link to the datasheet in case you need it:
https://www-ssl.intel.com/content/www/us/en/ethernet-controllers/ethernet-controller-i350-datasheet.html Intel® Ethernet Controller I350: Datasheet
Mark H
Mark_H_Intel
Hi Erick,
Mark H
EFrei2
Yes, as the Intel Pro PT (PCIe) that has 192 KB Cache and the Intel Pro ET (PCIe) 256 KB Cache.
Mark_H_Intel
Hi Erick,
The numbers you gave do not correspond to any cache structures that are familiar to the engineers I asked. So I think that I still don't understand your question. Can you tell me where the 192 KB and 256 KB numbers came from? If we can see where you got those numbers, then I can probably find an answer for the I350.
Mark H
EFrei2
Hi Mark,
I found what I was looking for in the datasheet...host buffer...thanks for your assistance...
