Ethernet Products
5720 Discussions
Can Intel I211 handle gigabit speed?
MH30
Hello to everyone, this is my first post here.
I have a computer based on Asrock X570 Pro4 motherboard, which has Intel I211 ethernet. My internet has been upgraded from 500 Mbit / 100 Mbit some couple days ago to 1 Gbit / 200 Mbit. My issue is that every time I check the internet speed using the Speedtest.net website or Windows 11 application from Microsoft Store I only get 850 Mbit download speed, while upload speed is fine.
Before I contact my ISP support I would like to know if I211 can handle 1 Gbit download speed. I have already tried some solutions like upgrading to latest version of drivers (Release 28.2.1) from Intel website  since Asrock doesn't care to update its support site and also to manually adjust Speed & Duplex setting from "Auto Negotiation" to "1 Gbps Full duplex". Unfortunately the download speed stayed the same. I tried to connect the computer directly to the modem I have received from my ISP rather than my personal router. Again, the download speed stayed the same. Finally I would like to note that I use CAT7 cables which should easily handle 1 GBit speed.
Thanks in advance for the support
Yogaeasvaran
Greetings Mr. Mitja,
Thank you for contacting Intel Customer Support.
As per checking, this Ethernet I211 supported 1GbpE speed.
You may also check the link below:
Intel Ethernet Controller I211AT Product Specifications
If you have any further questions or queries, please kindly let us know.
Thank You & Regards,
Yogaeasvaran
MH30
Thanks for your quick reply Yogaeasvaran. I have already contacted my ISP and they have confirmed the issue on their network.
MH30
Yogaeasvaran
Greetings Mitja,
Thank you for the feedback.
Since you have confirmed that there is issue from their end, therefore we are proceeding to close this ticket.
If you have any more questions in the future, please don't hesitate to post a new question, as this thread will no longer be monitored.
Yogaeasvaran
Intel® Customer Support
