Ethernet Products
5567 Discussions
Can be two distinct Intel EXPI9301CT put into LACP team?
AGvoz
Intel EXPI9301CT has one copper port. What if I install two cards into one machine? Can they be put into one LACP group on Windows Server 2008 R2 (not 2012!) by means of Intel drivers? Any other teaming mode will also be enough, LACP is not a requirement.
Thanks in advance guys!
VincentT_T_Intel
Hi Alex, I've tried 2 EXPI9301CT on win2k8 R2 Enterprise and was able to create LACP group, just make sure to install the driver. You can get the driver from the link below:
https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=18725 https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=18725
Other teaming mode can also be configured such as load balancing, fault tolerance, for details of each teaming mode, kindly check out the link below:
http://www.intel.com/support/network/sb/cs-009747.htm Network Connectivity — How do I Use Teaming with Intel® Advanced Network Services (Intel® ANS)?
Hope this help.
VincentT_T_Intel
Hope this help.
AGvoz
Thank you!
This was of great help! I was just searching if I can buy cards for low-end server with aggregation capabilities. Now I know that I can and that it will work.
