Ethernet Products
5182 Discussions
Can't capture pkts with an ethertype less than 0x05DC
NicoN
Hello, I am using an intel I350 card (igb driver) to monitor a specific network. Frames on this network have an ethertype less than 0x05DC. Tcpdump does not capture any frames on any port of the intel card, but if I use another card it works. I tried to modify all the parameters with ethtool, without success. Can you help me?
NicoN
Bonjour, le port est connecté sur un réseau ethernet avec un ethertype commençant par 0x01... ce qui normalement  doit correspondre a la taille de la trame, mais ce n'est pas le cas, l'ethertype correspond a un type de trafic (non ip).  Est il possible d'utiliser une carte intel pour un reseau autre qu'IP ? avec des ethertypes commencant par 0x01...?
Sazirah
Hi NicoN,
Please give me some time to check from my end and revert back to you as soon as possible regarding the issue.
Sazzy_Intel
Sazirah
Hi NicoN,
Good day,
My apologies for taking some time to revert back here.
Regarding this, we have expert team to assist you further related to this issue. You may contact our IPS team by visiting link below. https://www.intel.com/content/www/us/en/design/support/ips/training/welcome.html
If you have any questions, please let me know.
Sazzy_Intel
Sazirah
Hi NicoN,
This is related to your enquiries above, I would like to check if the issue has resolved?
If you have any questions or clarifications, please let me know.
Sazzy_Intel
NicoN
Bonjour Sazirah, le problème n'est pas résolu et nous n'avons pas eu le temps d'investiguer plus. Pour le moment nous prévoyons d'utiliser une autre carte.
Cordialement
Nicolas
Sazirah
Hi NicoN,
Thank you for your replying.
This is noted, if you have time to proceed, feel free to contact our IPS team to check on this issue. You may visit link below to contact them:
Since you are currently using other card, may I know if you require any help from our end? If no, we will proceed to close this forum.
Sazzy_Intel
Sazirah
Hi NicoN,
Good day.
This is regarding your enquiries above. Since we have not seen an update, if you need any additional information, please submit a new question as this thread will no longer be monitored.
Sazzy_Intel
