Ethernet Products
5769 Discussions
Can't generate netlist, license for encrypted file is not available
Using Quartus® Prime version 16.0 compiling MegaCore
“Triple-Speed Ethernet MegaCore”
The process doesn’t terminate, the message bellow is received:
Error (204009): Can't generate netlist output files because the license for encrypted file "…../Triple/altera_tse_mii_tx_if.v" is not available.
I must ephasize that I implement:
Assignments => settings => Compilation Process settings => More settings =>
“Disable OpenCore Plus hardware evaluation” as off
Can someone help me How to resolve this error?
Hi Ramimar,
You are unable to generate the netlist output files for the OpenCore plus feature.
The workaround is to disable the EDA simulation tool in your project by opening the*Settings*dialog box from the Quartus II Assignments menu. Select the category*EDA Tool Settings*and the subcategory*Simulation. On the*Simulation*page of the*Settings*dialog box, change the*Tool name*option to*<None>.
Terence
(This message was posted on behalf of Intel Corporation)
