Ethernet Products
4628 Discussions
Can't get 25G to link up back to to back (XXV710) Linux 16.04
MYang22
I have Silicom quad http://http//www.silicom-usa.com/pr/server-adapters/networking-adapters/25-gigabit-ethernet-networking-server-adapters/pe31625g4i71l-server-adapter/ 25G NIC's, it is using XXV710-AM2.
I'm using Avago 25G-SR http://www.foxconnconnector.com/sale-9183978-avago-afbr-725smz-25-gbd-mmf-sfp-optical-transceiver-for-25gbase-sr-ethernet-850nm-100m-lc-connector.html SFP, and I have two interfaces hooked up back to back, I can't get a link.
I'm using the latest and greatest i40e driver (version 2.4.10)
This is what I see from ethtool
apcon@utraffic25:~/working/drivers/hw_debug$ sudo ethtool enp59s0f0
Settings for enp59s0f0:
Supported ports: [ ]
Supported link modes: 1000baseT/Full
Supports auto-negotiation: Yes
Advertised link modes: 1000baseT/Full
10000baseT/Full
Advertised auto-negotiation: Yes
Speed: Unknown! (65535)
Duplex: Unknown! (255)
Port: Unknown! (255)
PHYAD: 0
Transceiver: internal
Auto-negotiation: off
Supports Wake-on: g
Wake-on: g
Current message level: 0x0000000f (15)
Link detected: no
apcon@utraffic25:~/working/drivers/hw_debug$ sudo ethtool -i enp59s0f1
driver: i40e
version: 2.4.10
firmware-version: 6.02 0x80003a08 1.1691.0
bus-info: 0000:3b:00.1
I see link LED's responding just fine on the hardware, but I don't see the link state changing from linux
So my initial suspicions are:
1. Non-Intel SFP's are just not supported. Which is really odd for Intel NICs since all my 10G and 40G Intel NICs work wirth Avago.
2. Do I have to pass some drivers parameters to i40e?
Hello Morgany,
Thank you for posting in Intel Wired Ethernet Communities. Are both adapters being used the same model, If you connect to another device will it work? Please check that the PCI-e interface is 3.0 supporting full 8X on your system. Please see the following https://www.intel.com/content/www/xa/en/support/articles/000023708/network-and-i-o/ethernet-products.html link for SFP28 compatibility with XXV710. We only list one Intel module. You may verify additional supported modules with Silicom, and check if they provide additional drivers or firmware. Please let us know if you have other questions.
Daniel D
Intel Customer Support
Agent under contract to Intel
MYang22
Hi Daniel:
To answer your question.
1. The two interfaces on the same card. I also tried plugging into an identical card on the same system. I bought 6 identical cards.
2. All cards are on PCI-E 3.0 compliant interfaces. I have verified this.
3. The cards were shipped with firmware 6.0.2, I did not have to update this via NVM
Again, I notice the LED's are showing active links, just not the driver stack.
Morgan
Hello Morgany,
Thank you for the information. Did you also verify the module compatibility with Silicom? From the image provided the ACT link LED appears to be off on the left port; please confirm if it is off or blinking. Have you used the same cable for each test? Would you be able to see if one of the adapters can detect a link from another system or OS? Please provide ifconfig output, modprobe i40e followed by dmesg output, as well as lshw -class network. Will investigate the issue further with the information provided.
Daniel D
Hello Morgany,
Please let us know if you still need assistance with this issue. If you solved this issue, please inform us. If you have any questions please do not hesitate to ask.
Daniel D
MYang22
Hi:
Sorry for the delay. It turns out I was able to get link up running Ubuntu 18.04
apcon@utraffic25:~$ sudo ethtool enp94s0f0
Settings for enp94s0f0:
Supported ports: [ FIBRE ]
Supported link modes: 25000baseSR/Full
Supported pause frame use: Symmetric
Supported FEC modes: Not reported
Advertised link modes: 25000baseSR/Full
Advertised pause frame use: No
Advertised FEC modes: Not reported
Speed: 25000Mb/s
Duplex: Full
Port: FIBRE
PHYAD: 0
Supports Wake-on: g
Wake-on: g
Current message level: 0x00000007 (7)
drv probe link
Link detected: yes
apcon@utraffic25:~$ sudo ethtool -i enp94s0f0
driver: i40e
version: 2.1.14-k
expansion-rom-version:
bus-info: 0000:5e:00.0
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: yes
Now, the strange news, I have a quad NIC, but only 2 out of 4 NIC's are initialized by the driver. In fact, running "lspci" only shows 2 25G interfaces on that particular PCI address
-+-[0000:d7]-+-00.0-[d8]--+-00.0 Intel Corporation Ethernet Controller XXV710 for 25GbE SFP28
| | \-00.1 Intel Corporation Ethernet Controller XXV710 for 25GbE SFP28
| +-05.0 Intel Corporation Device 2034
| +-05.2 Intel Corporation Sky Lake-E RAS Configuration Registers
| +-05.4 Intel Corporation Device 2036
| +-0e.0 Intel Corporation Device 2058
| +-0e.1 Intel Corporation Device 2059
| +-0f.0 Intel Corporation Device 2058
| +-0f.1 Intel Corporation Device 2059
| +-12.0 Intel Corporation Sky Lake-E M3KTI Registers
| +-12.1 Intel Corporation Sky Lake-E M3KTI Registers
| +-12.2 Intel Corporation Sky Lake-E M3KTI Registers
| +-15.0 Intel Corporation Sky Lake-E M2PCI Registers
| +-16.0 Intel Corporation Sky Lake-E M2PCI Registers
| \-16.4 Intel Corporation Sky Lake-E M2PCI Registers
So the good news i'm getting a link. But news is i'm only getting 2 out of 4 interfaces
Hello Morgany,
Please let us know the brand and model of the system these network adapters are being used on. All 4 ports are connected to another identical adapter on the same system? Are the two detected interfaces constant even after a reboot or power cycle, or do they alternate? Are all of the link lights still on, or just 2 of the ports? Kindly contact Silicom to confirm compatibility with the system and SFP modules. Please let us know if you have any questions.
Daniel D
Hello Morgany,
Please let us know if you still need assistance with this XXV710 controller. We have not received a reply in some time. Please do not hesitate to reply if you no longer need assistance, or have any questions.
Daniel D
Hello Morgany,
Have you managed to resolve this issue? Please let us know if you still have any questions.
Best regards.
Daniel D
dsevi3
سلام ایا شما تابحال به سایت هایی که اصلا ربطی به اینتل ندارند سر زدید ؟ اگر به بحث های عطر و ادکلن علاقه مندید حتما به سایت زیر یر بزنید
https://atrpich.com/product/mont-blanc-legend-mens-eau-de-perfume/
