Ethernet Products
5821 Discussions
Can't install my intel drivers (prosetdx.msi problem)
CSant11
Hi! I'm trying to install my ethernet controller driver (Intel(R) Ethernet Connection I217-V) but this thing keeps popping on the installation process
Tried installing different intel softwares from this https://downloadcenter.intel.com/product/71305/Intel-Ethernet-Connection-I218-V Intel® Download Center same result.
Tried using Intel Driver Update Utility but it won't detect my ethernet controller.
My intel chipset is updated.
please help!
st4
New Contributor III
Hi ccaarrll,
Thank you for the post. What is the system board for this Intel(R) Ethernet Connection I217-V)? What is the operating system?
wb
CSant11
Hello! My motherboard is H97N-WIFI and my OS is Windows 7
st4
New Contributor III
Hi ccaarril,
I understand you are using a Gigabyte board.. it is recommended to obtain the driver from the board vendor. You may visit the website below for the drivers
http://www.gigabyte.ph/products/product-page.aspx?pid=4992# dl GIGABYTE - Motherboard - Socket 1150 - GA-H97N-WIFI (rev. 1.0)
Please choose your operating system (32bit or 64bit).
Hope the above info helps,
rgds,
wb
