$ make
make[1]: Entering directory '/usr/src/kernels/5.0.10-1.el7.elrepo.x86_64'
CC [M] /home/amindomao/intel/i40e-2.7.26/src/i40e_main.o
In file included from /home/amindomao/intel/i40e-2.7.26/src/i40e_main.c:9:0:
/home/amindomao/intel/i40e-2.7.26/src/i40e_helper.h: In function ‘i40e_allocate_dma_mem_d’:
/home/amindomao/intel/i40e-2.7.26/src/i40e_helper.h:24:2: error: implicit declaration of function ‘dma_zalloc_coherent’ [-Werror=implicit-function-declaration]
mem->va = dma_zalloc_coherent(&nf->pdev->dev, mem->size,
/home/amindomao/intel/i40e-2.7.26/src/i40e_helper.h:24:10: warning: assignment makes pointer from integer without a cast [enabled by default]
/home/amindomao/intel/i40e-2.7.26/src/i40e_main.c: At top level:
/home/amindomao/intel/i40e-2.7.26/src/i40e_main.c:12783:2: warning: initialization from incompatible pointer type [enabled by default]
.ndo_bridge_setlink = i40e_ndo_bridge_setlink,
/home/amindomao/intel/i40e-2.7.26/src/i40e_main.c:12783:2: warning: (near initialization for ‘i40e_netdev_ops.ndo_bridge_setlink’) [enabled by default]
cc1: some warnings being treated as errors
make[2]: *** [scripts/Makefile.build:277: /home/amindomao/intel/i40e-2.7.26/src/i40e_main.o] Error 1
make[1]: *** [Makefile:1575: _module_/home/amindomao/intel/i40e-2.7.26/src] Error 2
make[1]: Leaving directory '/usr/src/kernels/5.0.10-1.el7.elrepo.x86_64'
make: *** [default] Error 2
I've tried to make the driver from 2.7.29 sources also - result is the same.
With older kernels like 4.4.179 the driver could be compiled.
- I have not got any NIC yet. I'm just trying to get recent drivers for the NIC I'm going to buy.
- My OS is Centos with mainline kernel from community approved repository - ELRepo.
- System is Dell R620.
I've tried different versions of gcc also, with no success.
Hello!
I have Linux OS, CENTOS 7.5 exactly. I'm using a main line linux kernel version 5.0.10 and trying to build intel xl710 driver for my OS. I've tried driver versions 2.7.26 and i40e-2.7.29 - the result is the error during building process, which part is in my first post.
Look at the screenshot please.
Ok. Lets try in another way.
I've downloaded the driver I need ( look at the above screenshot ); unpacked it and followed the installation instruction from README file.
The error from my initial post I've got after running the fourth step.
Thank you for your time. I'll be here :)
