Ethernet Products
5530 Discussions
Can we retrieve digital diagnostic info from INTEL SFP+/NIC X520 from OS?
I would like to be able to issue a command from LINUX to retrieve transmitted optical power, received optical power.
Is there any Intel software utility to get that info?
Hi pdecary,
Thank you for the post. I need to check if we have such software, by the way, what is the purpose of obtaining this information?
wb
Hi Pdecary,
What you can do is to get the information from the switch side, sample command - show fiber-ports optical-transceiver , you may refer to website below for the command.
https://ubuntuforums.org/showthread.php?t=2141166 (note this is third party website for your reference, Intel has no control over the content post therein).
thanks,
wb
Hi pdecary,
Have you tried the suggestion? Please feel free to update me.
thanks,
wb
