I am trying to verify the operation using the I210 driver in openAvnu.
I encountered an error while executing igb_avb under the openAVnu source.
~/OpenAvnu/examples/simple_talker$ sudo ./simple_talker -i enp3s0 -t 2
attaching to 0000:03:00.0
attach failed! devpath=0000:03:00.0 (Unknown error -6)
connect failed (Is a directory) - are you running as root?
The error occurred in the igb.c file at the following code. I tried modifying it as shown in the second code, but the error remains the same.
original code : adapter->ldev = open("/dev/igb_avb", O_RDWR);
modified code : adapter->ldev = open("/sys/devices/pci0000:00/0000:00:1d.0/0000:03:00.0", O_RDWR);
After mount the driver, I verified that it exists even though I haven't installed sw driver addtionally.
While I was downloading and installing the igb_avb source to use the I210 driver from openAVnu, I encountered an error.
used source link : https://github.com/Avnu/igb_avb
Although the build was successful, I encountered an error while performing insmod as follows.
~/OpenAvnu/lib/igb_avb/kmod$ sudo insmod ./igb_avb.ko
insmod: ERROR: could not insert module ./igb_avb.ko: Key was rejected by service
Can you help me resolve this issue?
thanks.
Hi 365days,
While we are checking on the resolution that may help your issue, may I know have you tried to do clean driver installation?
Sazzy_Intel
Hello, Saziah
What does "clean driver installation" mean?
Can you explain the "clean driver installation" in detail?
I tried downloading and installing Source as https://github.com/Avnu/igb_avb ".
And I tried igb-5.15.7.tar.gz as https://www.intel.co.kr/content/www/kr/ko/download/14098/intel-network-adapter-driver-for-82575-6-82580-i350-and-i210-211-based-gigabit-network-connections-for-linux.html.
Hi 365days,
Also, may I know the specific model for your Intel i210?
And can you advise if this Intel i210 used in what system.
Sazzy_Intel
Hi Sazirah,
Intel Ethernet I210-T1 PCI2 X1 Gb NIC
OS : Utunbtu 22.04
I want to use I210 to run openAvnu by installing Ubuntu22.04 on my desktop.
Hi 365days,
Thank you for details provided. May I know have you tried to update the driver via Intel website as below:
Intel® Ethernet Adapter Complete Driver Pack
Sazzy_Intel
Hi Sazirah,
I followed your guide and proceeded with the installation. However, I still encountered the same problem.
$ sudo find ./ -iname *ixgb* ./6.2.0-39-generic/kernel/drivers/net/ethernet/intel/ixgbevf ./6.2.0-39-generic/kernel/drivers/net/ethernet/intel/ixgbevf/ixgbevf.ko ./6.2.0-39-generic/kernel/drivers/net/ethernet/intel/ixgb ./6.2.0-39-generic/kernel/drivers/net/ethernet/intel/ixgb/ixgb.ko ./6.2.0-39-generic/kernel/drivers/net/ethernet/intel/ixgbe ./6.2.0-39-generic/kernel/drivers/net/ethernet/intel/ixgbe/ixgbe.ko ./6.5.0-14-generic/updates/drivers/net/ethernet/intel/ixgbe ./6.5.0-14-generic/updates/drivers/net/ethernet/intel/ixgbe/ixgbe.ko ./6.5.0-14-generic/kernel/drivers/net/ethernet/intel/ixgbevf ./6.5.0-14-generic/kernel/drivers/net/ethernet/intel/ixgbevf/ixgbevf.ko ./6.5.0-14-generic/kernel/drivers/net/ethernet/intel/ixgbe ./6.5.0-14-generic/kernel/drivers/net/ethernet/intel/ixgbe/ixgbe.ko mmtp@mmtp-B80GV-AP05D6E:/lib/modules$ cd ~ mmtp@mmtp-B80GV-AP05D6E:~$ cd ixgbe-5.19.9/ mmtp@mmtp-B80GV-AP05D6E:~/ixgbe-5.19.9$ modprobe ixgbe modprobe: ERROR: could not insert 'ixgbe': Operation not permitted mmtp@mmtp-B80GV-AP05D6E:~/ixgbe-5.19.9$ sudo modprobe ixgbe modprobe: ERROR: could not insert 'ixgbe': Key was rejected by service |
Hi 365days,
Thank you. Let me check from my end regarding this issue and revert back to you.
Sazzy_Intel
Hi Sazirab,
I will wait for your response.
365days
Hi 365days,
We have discussed regarding this issue, and we advise you to contact our Intel Embedded team. You may post in the Embedded forum regarding this and they will assist you regarding your issue. Please visit below link to contact our Intel Embedded team:
https://community.intel.com/t5/Embedded-Connectivity/bd-p/embedded-networking-connectivity
Sazzy_Intel
Hi 365days,
Good day,
This is related to your enquiries above, I would like to check if the issue has resolved?
If you have any questions or clarifications, please let me know.
Sazzy_Intel
Hi 365days,
Good day.
This is regarding your enquiry above.
Since we have not seen an update, we will be closing this forum case from our end. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Sazzy_Intel
