I want to generate X722 option ROM(PXE&iSCSI) by Bootutil. The tool didn't support X722 device ID to generate LOM file. But I can use '-up=iscsi' command to flash option rom and the iscsi function works fine on system. Is there any other way to solve this problem?
Bootutil version: 23.5.1
Hello ALiao,
Thank you for posting in Intel Ethernet Communities. Please let us know the board model the X722 is integrated into. What version of Windows are you running? Please also confirm the BootIMG.FLB file is the one included in 23.5.1. It may also be that the operation is unsupported due to changes by the board manufacturer. Please also see "BootUtil is not intended for LOM" in the following link:
https://www.intel.com/content/www/xa/en/support/articles/000005790/software/manageability-products.h...
Let us know if you have any questions.
Daniel D
Intel Customer Support
Under Contract to Intel Corporation
Hello ALiao,
Please let us know if you still need assistance with this issue. If you have resolved the issue with the board manufacturer please inform us. Let us know if you have any other questions.
Daniel D
Hi Daniel,
Thanks for your support. I have solved this issue by BootUtil version 19. BootUtil version 19 can generate x722 lom file using 'lom' command.
ALiao
Hello ALiao,
Thank you for the update. Glad you were able to find a workaround. If you have any other questions, please do not hesitate to ask.
Daniel D
