Ethernet Products
5608 Discussions
Cannot install drivers. No Intel(R) Adapters are present in this computer.
qcao
I am having a trouble with my PC. I am not able to connect with Internet after I restarted my computer to finish some updates for Windows10. I found there is problem with ethernet controller, the "Intel(R) Ethernet Connection I217-LM" cannot be updated. I download drivers from the Intel website https://downloadcenter.intel.com/download/25016/Network-Adapter-Driver-for-Windows-10 Download Network Adapter Driver for Windows® 10 and tried to install the network drivers on my PC, but got the error "Cannot install drivers. No Intel(R) Adapters are present in this computer."
The network troubleshoot is as follows
Ethernet Controller has a driver problem
Not fixed
There is a problem with the driver for Ethernet Controller. The driver needs to be reinstalled.
Device information
Name:
Ethernet Controller
ID:
PCI\VEN_8086&DEV_153A&SUBSYS_05A61028&REV_04\3&11583659&0&C8
Error code:
18
please help me with this problem, I really appreciate it
Hi Cindy10086,
Thank you for the post. What is the brand and model of your PC? The driver available on our Intel website is a generic driver, it is recommended you contact the board vendor to obtain customized driver that is for your I217-LM for your system. Have you tried contacting the board vendor already?
wb
qcao
Thanks for your suggestion. The problem has been already solved.
Hi Cindy10086,
Thank you for the update, I am problem is resolved.
rgds,
wb
