Ethernet Products
5821 Discussions
ComExpress Setting the Ethernet PHY to Compliance Test modes
MosheSaban
I want to test ethernet compliance for 1000BaseT so i want to test the required test modes on the MDI lines.
I'm using the ComExpress6 model TC570-I7-1185GRE
Datasheet conga-TC570
The Ethernet route is:
Intel_SOC <---(Pcie)---> intel controller i226 <---(MDI)---> connector
can you please share a document that described it?
Amina_Sadiya
Hello Team,
Greetings from Intel!
Thank you for your response, Regarding your query as you are looking for the document of MDI. I recommend raise a request in Intel® Resource and Documentation Center (RDC) with Developer Zone premier access for your query.
If you do not have an Intel® Resource and Documentation Center (RDC) with Intel® Developer Zone (Intel® DevZone) account, kindly refer to the link below. Please be informed that you will need a premier account with CNDA access in order to access the files.
https://www.intel.com/content/www/us/en/support/articles/000058073/programs/resource-and-documentation-center.html
Amina
Amina_Sadiya
Hello Team,
As mentioned earlier, regarding your query, as you are looking for the document of MDI. We recommend raise a request in Intel® Resource and Documentation Center (RDC) with Developer Zone premier access for further assistance. Since no additional support is available from our end, we will proceed with closing this case.
Amina
