Hello Team,
Can you please advise compatible cable for Ethernet Network Adapter E810-CQDA2? Prt length must be in between 2m, 1.5m,1m,0.5m and 5m. Can you please recommend part numbers?
Thank you in advance.
Kind Regards,
Hello MO-WING,
Kindly go thru below link to check the product compatibility peripherals for Intel® Ethernet Network Adapter E810-CQDA1 / CQDA2
Please let us know if you have any questions or difficulties.
Hayat
Intel Customer Support
Hi MO-WING,
Please give me some time to check on this request and I will get back to you.
Sazzy
Hello Sazzy, thank you for the update.
Hello MO-WING,
Hayat
Hello MO-WING,
Good day,
This is related to your enquiries above, I would like to check if the issue has resolved?
If you have any questions or clarifications, please let me know.
Sazzy_Intel
Hi MO-WING,
Good day
This is regarding your enquiries above. Since we have not seen an update, if you need any additional information, please submit a new question as this thread will no longer be monitored.
Sazzy_Intel
