Ethernet Products
4359 Discussions
Connection Loss
DMitc6
Intel(R) Ethernet Connection I217-V so I have a feeling this adapter has a problem or something I just keep losing connection every couple hours or so. on the rare occasion a day or two can any please help its really starting to get on my nerve
st4
New Contributor III
Hi MonkNZ,
What is the system you used as this is an onboard NIC, what you can do is to check the cable first and the connection.
If the cable is good, change the port where the NIC was connected.
Try un-install and re-install teh driver and upgrade the latest driver provided by the system vendor.
Hope this helps.
rgds,
wb
