Ethernet Products
4853 Discussions
Connection from XL710 for 40GbE QSFP+ to N3000 XXV710 for 25GbE SFP28
KarthikPoojary
Hi
We were trying to connect XL710 for 40GbE QSFP+ to N3000 XXV710 for 25GbE QSFP28(direct connection) but we are seeing that link itself is not coming up.
Is this connection not supported or is there any configuration required to make this work?
Please LMK if any additional info is required
Karthik
Caguicla_Intel
Hello KarthikPoojary,
We are sorry to hear that you are experiencing issue on your setup. Kindly provide the following information for us to proceed checking your query.
1. Just to confirm, are you using the following products?
Intel® Ethernet Converged Network Adapter XL710 10/40 GbE
https://www.intel.com/content/www/us/en/products/docs/network-io/ethernet/network-adapters/ethernet-xl710-brief.html
Intel® FPGA Programmable Acceleration Card N3000
https://www.intel.com/content/www/us/en/programmable/products/boards_and_kits/dev-kits/altera/intel-fpga-pac-n3000/overview.html
2. Operating System used
3. Current driver and firmware version used
4. If possible, please share the PBA of the adapter. You may refer to the link below on where to find the PBA number. It consist of 6-3 digit number located at the last part of the serial number. This would help us identify if you are using an Original Equipment Manufacturer(OEM) or retail version of Intel Ethernet Adapter.
Identify Your Intel® Network Adapter Model Using PBA Number
https://www.intel.com/content/www/us/en/support/articles/000007022/network-and-i-o/ethernet-products.html
5.Model of optical modules and cable type used
We hope to hear from you soon.
Should there be no response, I’ll make sure to reach out after 3 business days.
Crisselle C.
Intel® Customer Support
Caguicla_Intel
Good day!
This is just a follow up message for the information we requested so we can proceed checking your query. In case you have additional questions or clarifications on this matter, please feel free to let us know.
Awaiting to hear from you.
We will follow up after 3 business days in case we don't receive a reply.
Crisselle C.
Intel Customer Support
Caguicla_Intel
How are you doing?
Please be informed that we will now close this request since we haven't received any response from our previous follow ups. Just feel free to post a new question if you may have any other inquiry in the future as this thread will no longer be monitored.
May you have a good day and stay safe!
Crisselle C.
